Results 1 to 29 of 29
Thread: 2.2l
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    2.2l
    now how is this achieved? ive seen 2.0L and ive seen some 2.2s in VWs but no ones doing it in the audis.
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: 2.2l
    prob a stroker kit
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: 2.2l
    Quote Originally Posted by whiteUSPflow View Post
    you need a tdi block from Europe
    - Clint
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: 2.2l
    Yup, the 1.8's cylinders walls are already thin enough going up to a 2.0....a 2.2: would be feasable
    -Sami-
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: 2.2l
    The limit is not the walls,its the deck height.
    OP if you want a 2.2 Kit contact me via PM.I sell the parts and I also build the bottom ends per your specs.
    Jun 30 2007
    Raleigh, NC
    Re: 2.2l
    1.9L tall block ftw
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 22 2008
    Richmond, VA
    Re: 2.2l
    well thanks issam when i finally deside to do it i will contact you but do you think you could do this to my stock block?
    USP CLUB MEMBER #97
    Unitronic tuned RS6
    Feb 26 2006
    Earth
    Re: 2.2l
    Nope,cant be done to the 220mm block.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: 2.2l
    A 2.2 liter using a 100mm crank isn't exactly the best setup for making power since you cant rev it nearly as high as a well built 2.0 liter. Even the Evo guys that run a 100mm crank only rev to 8k while the 2.0 guys rev to 10,500. One of the reasons I am sticking to my 2032cc which I plan on running to 9500 soon.
    Feb 17 2005
    Sarasota, FL
    Re: 2.2l
    AEG can be stroked to 2.2l can't it? Using the stock crank (which 2.0 guys use and rev out) and some custom pistons
    Feb 22 2008
    Richmond, VA
    Re: 2.2l
    dam 10,500 now thats crazy
    USP CLUB MEMBER #97
    Unitronic tuned RS6
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: 2.2l
    What's the maximum displacement we can get by stroking our cars with out boring them out?
    What kind of characteristics would make Jordan stroke his to 2008cc and Mike go to 2032cc? RPM, power band... where/what are the trade-offs for going ever higher in displacement?
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Jul 07 2004
    socal
    Re: 2.2l
    Quote Originally Posted by Tactic12 View Post
    By adding a 2 lite crank you can get around 1.9 liter with the stock bore.
    2008cc is 83mm bore with 92.8mm crank while my bore is 83.5mm to get that extra 24cc. Most people dont go above 83mm because they think there isn't enough meat between the cylinders to go with 83.5mm bore, but yet I have been running 83.5 for 5-6 years now.
    The higher the displacement the more exhaust gas which means the turbo spools up sooner. Problem is that going with too long of a stroke means you have a lower rpm limit on how high you can rev it, higher revs makes up for the lower displacement.
    engine displacment calc in CC
    Jun 28 2007
    Edmonton, AB
    Re: 2.2l
    Nice, thanks!
    So, care to offer your take on the ideal balance between displacement and reliability? Stock bore with the 2L crank?
    Jun 28 2007
    Edmonton, AB
    Re: 2.2l
    Also, can you define over/undersquare for me?
    I know it's the relationship between bore/stroke but not sure the order of priority.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: 2.2l
    Quote Originally Posted by A4ringedONE8T View Post
    Shawn, your thinking about this wrong, the AEG block is basically an AEG crank with an 83mm bore
    I have that same setup on my motor right now, thats the problem is that the block is as high as the 06A block, the TDI block allows for the extra stroke
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: 2.2l
    square being bore = stroke
    oversquare being bore > stroke
    under square being bore < stroke
    some info: http://en.wikipedia.org/wiki/Stroke_ratio#Oversquare
    Here is some more reading from the B6 A4 FAQ forum: http://audizine.com/forum/showthread.php?t=187837
    I went with 82.5mm bore and 92.8mm stroke
    -Doug
    Feb 26 2006
    Earth
    Re: 2.2l
    A 2.2 liter using a 100mm crank isn't exactly the best setup for making power since you cant rev it nearly as high as a well built 2.0 liter..
    Thats not quite true Mike.Even with the 100mm stroke & 159mm we still maintain a rod ratio higher than 1.5.I have seen a 2.2 motor sing to 10000 rpm's so saying you cant rev a stroker is just a myth.
    Jul 07 2004
    socal
    Re: 2.2l
    Quote Originally Posted by Issam@034 View Post
    Is the EVO block shorter?
    Feb 26 2006
    Earth
    Re: 2.2l
    depends on which block
    4G63 or 4G64?
    Jul 07 2004
    socal
    Re: 2.2l
    4G63 or 4G64?
    2003 EVO8, not sure which one they have stock.
    Feb 26 2006
    Earth
    Re: 2.2l
    4G63 which is a shorter block
    Jun 28 2007
    Edmonton, AB
    Re: 2.2l
    Care to explain "rod ratio" and what the 1.5 has to do with anything?
    Just doing my part to responsibly join the built BAT club here... help a guy out!
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Jun 28 2007
    Edmonton, AB
    Re: 2.2l
    Cool thanks. But how does the rod ratio of 1.5 affect us? Why is that the buttah range? Or is it?!
    Jul 07 2004
    socal
    Re: 2.2l
    Higher rod ration means more stress on the rod. Even though the rod ratio is slightly higher when running a 2 liter crank in the 1.8T block it hasn't been an issue to anyone even for those that run to 8500 rpms.
    Feb 26 2006
    Earth
    Re: 2.2l
    True but coupled with Titanium rods & lightened JE pistons it certainly will help.
    I have a nasty 1.7 project in the works...
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    Re: 2.2l
    I saw this quite a bit when I was into mustangs, people always arguing about the rod ratio between a 331 and 347, and how a long rod 306 is a shitty idea, but no one ever had any problems with any of the combos.
    They also say it wears the cylinders funky because of the increased angularity, but I've never heard of anyone who's been able to prove there is any increased wear where the angularity is the highest which would would be in the middle of the cylinder.
    Does anyone have any real experience with a 2.2L that can provide any info?
    V8 Touareg - 1G TSI AWD - WRB WRX
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: 2.2l
    Quote Originally Posted by Four Play View Post
    Issam is building one...
    FYI you can also make a 2.1 with your block and just the TDI crank
    - Clint
