Results 1 to 9 of 9
    Registered Member Two Rings
    Sep 25 2007
    Santa Fe, New Mexico
    Stasis Alcon rear brakes, help
    I had my new brakes professionally installed last. On my way home from tonight, i had to make stop and I noticed that the center cap (plastic) was missing. When I got home, I noticed that the wheel was real hot and that the writing on the pads was like melted. The other side was ok. I have to be at work early or I would stop by the shop. Do you think the rotor will warp?
    2004 A4 Quattro 1.8T USP 6MT (white) XM, Ipod
    35% tint, AT Italia Spider wheels, BFG KDW 2, 235 40 18, K & N, RS4 Rear Sway bar, STaSIS Alcon rear brake upgrade.
    USP Club Member #80
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Re: Stasis Alcon rear brakes, help
    Quote Originally Posted by RicA4B6 View Post
    Was the rotor a reddish/orange color? Do the rear rotors side to side look any different in color/texture? Perhaps the shop didn't install one side correctly and the one rotor assy has some drag or something.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Sep 25 2007
    The e-brake cable is too short and binds. The rotor is a darker grey now. I sent an e-mail to Stasis about this. The brakes were installed correctly. I stopped by the shop this am.
    USP Club Member #80
    Sep 25 2007
    Turns out the e-brake cable was binding. Stasis says you should leave the cable unclipped. They don't give that instruction of course. They don't even tell you which is left or right. The instructions tell you about an attachment for bedding, which was not there. You pay almost $1,000 with install and nothing fits correctly. If anyone wants to buy this kit, pm me first.
    USP Club Member #80
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Yeah... the e-brake cable needs to be left unclipped or it will stretch and then drag the pads on the rotor.
    Sep 25 2007
    The instructions suck, they should tell you this. It is hard to tell when you are installing.
    USP Club Member #80
    Buncha motorcycles
    Memphis, TN
    so you dont have ebrake with the stasis rear upgrade?
    APR Stage 2/AWE Intake
    May 27 2004
    Portland, OR
    Quote Originally Posted by Papachristou View Post
    Yes you do. They're talking about essentially attaching/clipping the line in (to a bracket) or not.
    Jeremy Williams
    Jun 11 2005
    Vancouver, BC
    We^^^ What he said. We were referring to putting the brake cable back into the OEM clips which does not work so well.
    Once the suspension moves it will stretch the cable and drag the pads onto the rotor.
