Results 1 to 36 of 36
    Senior Member Two Rings 220013047's Avatar
    Apr 12 2007
    Where can I buy Catalytic converters for B6 3.0
    Hi,
    I got a CEL code P0431 and was told by my mechanic that I would need to buy new cats. How many cats are on a B6 3.0 and where can I buy them for a normal price?
    Thank you for your help.
    Established Member Two Rings tj19855's Avatar
    Jun 30 2008
    2003 Audi A4 Quattro 3.0 (B6)
    Houston, TX
    Re: Where can I buy Catalytic converters for B6 3.0
    Im on the same boat with you, I have looked everywhere and have found none only at dealer for $850 each.
    Buncha motorcycles
    Memphis, TN
    common 3.0 problem... are u over 80,000 miles?
    APR Stage 2/AWE Intake
    Apr 12 2007
    Yes, I am at 114K. The car runs great though. I had all major work done for the miles.
    Here is what the dealer told me today. Code P0431 is definitly a catalytic related code. Here is the worst part.......they quoted me $2,200 for one cat and two O2 sensors plus labor. Ha ha, these people don't have these dollars for anything!
    Go to genuinevwaudiparts and get yours for little less than the dealer ($100-150). With all the bolts and nuts and seals, one cat is around $750 plus $100 core charge. Keep in mind that it is a refurbished one, but new.
    So, my Audi 3.0 friends and others. If you get a P0431 bank 1,2 code, prepare yourself to spend big bucks.
    It sucks, but I hate the check engine light.
    Ps. Thank you Old Guy for your help and fast reply! You are the best
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    don't buy Cats for the car. wait for the cat-less downpipes. it's better
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Dec 11 2006
    Boston
    You can buy a generic cat for about $80 and have an exhaust shop weld it in for you for another $50 or so.
    Stage 3+ RS6's
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Quote Originally Posted by Maverick View Post
    Didn't Steve post up that these were done? I'm still waiting for mine.
    Apr 12 2007
    What is a cat less downpipe and where can I buy it? Is there a cheaper place to buy an OEM?
    Thanks
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Thats funny but OEM cats cost more than aftermarket HFC.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    i got both failed catss. P0431 , P0421.
    Dealer just ordered those parts from germerny today. delivery time 4-6 weeks.
    Lucky my car is 73k which is under 80k ferderal emission control warranty.
    From the statsistics, there are increasingly large amount of 2002 B6 3.0 cars's cats start to fail as their milage approach 90k and a lot of them already failed at early 70k.
    This is abonormal for cats cuz they are designed to last 150k+.
    However, not for those cats on B6 AVK-3.0 A4. (1.8T safe)
    Good luck and if you are one of those 02 AVK-3.0 ppl. Scan the code frequently and act fast for intermeeit P0431/P0421 immediately before the warranty expires.
    The efficiency below threshold code may occur already, but not serious enough to trigger CEL for early few monthes. but this is a sign that sooner or later your cats will go out.
    good luck everyone~
    check here:
    http://autos.msn.com/research/vip/Re...l=A4&trimid=-1
    Feb 16 2007
    MD, USA
    *Thread resurrection*
    Anyone happen to have an update on where to source a replacement cat for an AVK 3.0 at a reasonable price?
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Quote Originally Posted by 220013047 View Post
    Hi,
    Have you checked ebay? I seen some go from $100 OEM.
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    Yep. I'm in the same boat on my 3.0 failed CAT. Having a hell of a time getting the dealer to replace it also, they have all sorts of regulations and they will not replace it on the first code. It has to be cleared and come back three times, by the dealer and no one else. And if they "forget" to write it down then it doesn't count.
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Feb 16 2007
    MD, USA
    Quote Originally Posted by msharifi View Post
    Thanks for the lead. Right now I only see cats for an auto (I've got the 6 speed) but I'll keep an eye out.
    Oct 29 2005
    10speed
    San Francisco, CA
    why dont you guys get some antifoulers and be A-ok?
    - Clint
    Active Member One Ring NJ3Q's Avatar
    Apr 01 2010
    Finland
    Hi,
    I'm just wondering how you guys with the 3.0Qs got on with your Cat issues. The problem lies with the pre-cats, which die long before the main cats but since the car will have 2 units, each with a precat and main cat all as one piece then you end up swapping for new parts just because of the pre-cats. Of course this is probably stating the obvious now. I'm planning to cut out the precats and have generic sports cats or decat pipes welded in. This will mean putting the forward lambda/O2 sensors straight into the pipes or getting some kind of MIL eliminator gadgets.
    Any thoughts?
    cheers
    Nj
    B6 A4 3.0Q
    Scots-Irish living in Finland
    Veteran Member Three Rings meistah's Avatar
    Mar 28 2010
    vancouver, BC
    Sorry to necro-bump, but this thread contains the question I have, no point in reposting.
    For a cat failing issue on the 3.0L engine, could you just remove the precat as opposed to getting all new cats? And on that note would it improve performance without the negative side effects of removing the whole cat (smell and noise). From what I've read the catalytic converter system is similar to that of the 4.2 engine, and they just take out the precat for the jhm tune with no problems.
    And in doing that would I need antifoulers and/or software to get rid of the CEL?
    Jan 29 2010
    north ga
    On the 4.2 with the cats gone (gutted) you will get a CEL. JHM sells the O2 sensor spacers to trick the 02 sensor so that no CEL will come up.
    Not sure if the parts are the same for the 3.0, might want to check with JHM on that one (I'd be interested too since my 3.0 has close to 125k miles and I'll probably have cat problems here in the future)
    Mar 28 2010
    vancouver, BC
    Yea ill fire them an email. Just thought someone on the boards might know... Actually I'll post this up on the s4 forums in the meantime.
    Senior Member Two Rings jdigga99's Avatar
    May 13 2010
    BMW 330i
    Katy, TX
    Sigh...another issue to look forward too...
    2014 Lexus GS3350 F-sport
    2014 Audi SQ5
    "I'm in a silver bullet, caviar in the guts. 4 rings in her nose, a 3.0 on her butt..."
    Audi 3.0 group |VMR 19" 708's| Adam's Rotors - Race F&R| - SOLD
    Apr 01 2010
    Finland
    Would that error come from the front or rear sensors?
    I ask because I gutted my precats and welded two s8 cats on in place of the main cats near the end of last year. I'm now getting an open circuit error from one of the rear sensors but imagine it will be down to a bad conector or the sensor being old (I just put new front sensors in at the time).
    The guy who did the work for me didn't mention spacers and I haven't had any problems until now. So I guess my point is.. are the spacers really needed on the 3.0? Has anyone tried without?
    B6 A4 3.0Q
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    Quote Originally Posted by Das General View Post
    This is an option but the downpipe/cats will need to be removed from the car to do this, and if you have ever been under the 3.0 car and looked at the cats, the great design has the cat tucked up on the angled part of the downpipe, so its not located on the underside of the car on the horizontal pipe like traditional cars. so cutting the front part of the cat off is impossible since its not accessible while on the car, let alone welding in a new one. So why not just unbolt the downpipes? ha, cant get to the bolts unless the subframe is dropped with the engine or engine is lifted partially out. its basically a nightmare. <- this problem is the major hurdle with the 3.0 cars, its not really the cost of a cat, its the labor involved to replace one... let alone TWO. even if you go with catless down pipes you cant get away from this.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Established Member Two Rings BLkdOutTa4's Avatar
    Dec 02 2009
    central Pa
    P0421 just happened to POP up for me today...is it going to do anything to the performance and regular operation of the car if I don't replace the cat right away?
    Veteran Member Three Rings Dillon's Avatar
    Mar 16 2009
    91 mr2 turbo, Honda Ruckus
    Boone, NC
    Im just going to go oem. My Audi dealership has them for 550 each.
    2002 B6 3.0
    "To give up would be to give in to everything I hate." sns
    Established Member Two Rings takenotes's Avatar
    Apr 02 2011
    U.S
    shokan.com
    Apr 01 2010
    Finland
    Quote Originally Posted by BLkdOutTa4 View Post
    I cleared my codes and ran for weeks and sometimes months without them coming on again. I found low grade fuel set them off a bit but the codes will appear when the values the lambdas are reading are outside their ideal values. so you should be fine for a while but sooner is better to replce them before the precats start to disintegrate.
    550 is a hell of a good price by the way. is that US dolars? The dealer in Scotland wanted £2000 for the pair (probably about €3000) when I had my issues.
    B6 A4 3.0Q
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    If my cat starts dying again, I think I will just go with a testpipe (if one exists). Get myself an extra half horsepower
    Established Member Two Rings wheelmanbg's Avatar
    Nov 20 2010
    03 A4 3.0 Quattro
    Sheridan, WY
    I found some on ebay for around $250 each but I've just been reseting the code for now. I need to replace both of mine.
    Apr 12 2007
    Ok, I know this post is old, but the OEM replacement catalytic converter that I bought from genuinevwaudiparts is gone after almost 5 years on my 2002 b6 3.0. I have read that the EPA warranty is 8 year or 80K on new cars, but can someone tell me what the warranty for a replacement catalytic converter is. The EPA document does not address replacements and the warranty.
    Can someone shed some light if I still have warranty? When I replaced the cat, the car had 114K and now it has 156K. I purchased the cat on 7/9/08 and it was installed a week later.
    Thank you!
    Apr 01 2010
    Finland
    Thank you!
    I'm stunned the new one would die after such low miles but I seriously doubt that you'll have any joy with warranty on a cat after 5 years of use (despite the low mileage). I guess only the seller of the part can answer that for sure though. Have you had any issues with the other one or has it been fine from new? Just a thought but perhaps some external factor has caused the "new" cat to die? A bit of unburnt fuel getting through or something?
    B6 A4 3.0Q
    Veteran Member Four Rings 03a4b6ztk's Avatar
    Jun 21 2013
    North Carolina
    I have the pleasure of a 421 & 431 part few days coming back after 60 miles.I got a quote for 400 for the labor if I supply parts.
    Established Member Four Rings Ac101's Avatar
    Apr 21 2013
    Ct
    I have them ! Cats, downpipes, flex . All for 400 80k miles on it no damage
    Jun 21 2013
    North Carolina
    Quote Originally Posted by Ac101 View Post
    You willing to ship?
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    I've posted a bunch times where I bought a cat for $311 shipped to my door. way more expensive than weld-in for the 1.8t crowd, but we 3.0 owners drive a luxury car.
    you can find similar deals on partsgeek, partstrain, etc.
    but you have to be non-cali 6-speed.
    Established Member Two Rings i.am.gustav's Avatar
    Apr 21 2013
    New York
    This thread is super old but I got a direct fit HFC from Magnaflow for my car and it works perfectly fine plus they have a 50,000 milage warranty on the HFC.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    There's also a seller on eBay that offers test pipes or HFCs, for fairly cheap.
    -Tim
