Hey guys well my problems with my car still exist and I dont know what to do about it, unitronic doesn't answer emails so I am looking to the audi community for some insight on the persisting problems...
First I have so much timing pull it is ridiculous... here is a log of timing corrections, A/F ratio, block 3 and Boost
http://spreadsheets.google.com/pub?k...lVWMUF3d6zmCbA
if you look at the timing, I pull close to max timing when boost hits, my A/F ratio is right on spec, Boost takes forever to build to 19psi.
Here is what is installed on my car:
GTRS
Unitronics
Precision FMIC (350 HP core)
neuspeed TIP
bosch Green Giant 440cc injectors.@4 bar
VR6 MAF housing with a fairly new stock MAF sensor
APR 2.5" exhaust
Labree high flow cat
ATP Manifold.
Evo MS DV
K&N custom intake.
Apexi AVC-r boost controller...
First what can I do to lower the timing corrections? it is scary high, second why does it take almost until 5000rpms to spool this turbo? I dont know how everyone is saying that they are getting a full spool by 4000RPM's. I do not have any exhaust leaks, boost leaks or vacuum leaks. I have checked with an air compressor up to 15psi and also took it to a shop that hooked it up to a smoke machine and still no leaks... Also when boost hits, the overall timing is pretty low, is this normal or should it be higher?
