Results 1 to 16 of 16
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Hopefully resolved...
    Ok, had my wheels taken in to NTB to get my new tires put on. So excited! 255/35/19 on 19 x 8.5 ET43. Yeah, I got a little greedy. I guess I can't have my sidewall and width, too. Didn't clear the control arm and inside edge of the suspension by about 1-2 mm. AAAAHHHHH!!!!
    Settled with Tirerack, have to pay for shipping again, and have 245/35/19s on the way. Same tire, PS2. Their square shouldered profile probably explains the difficulty fitting them, but I need to know real quick if you think this will cause any problems. Moderate drop on PSS9s.
    Gratuitous wheel porn:
    Loaded up and ready to go:
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    Re: Emergency Tire Fitment Help!
    wow, i really like those rims...what kind are they?
    Jan 17 2008
    Evolution X
    Texas
    Volk CE28N. Weigh 18.9 lbs!!
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    John, unless someone has experience with that exact same setup, it's going to be tough getting accurate feedback. That said, going from 255 down to 245 you're effectively shortening the width of the tire by 10mm and if all you need is about 2mm to clear, that should do it. Another point of reference is that I'm running Falken 615s in 235 width on an 8.5" wide rim with ET32. 615s are more square than PS2s I don't rub with -1.3 camber in all four corners. I think you'll be fine with 245s.
    Jan 17 2008
    Evolution X
    Texas
    That's what I'm hoping. Thanks! I'm worried that the problems may stem from the 35 series sidewall, but it really is hard to say. It will not be good if these new tires don't fit, either.
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    Hum. The numbers seem to suggest that you will be fine. However if your into Autox there is a chance the inside tire could rub as the sidewall collapses.
    Of course centrifugal force could be enough to overcome this as the tire expands.
    Jan 17 2008
    Evolution X
    Texas
    I do occassionally track, I'll be dialing in the camber/toe once these are mounted. I am VERY hopeful they will fit. I really don't know what I'll do if they don't! Next time, I'll go for the 30 sidewalls...
    Big sigh of relief- Tirerack has the TE37s in 19 x 8.5 ET43 offset and has 245/35/19 as the reccomended size.
    http://www.tirerack.com/wheels/Wheel...e+Without+TPMS
    I'm pretty sure that means they'll work! I'm still bummed, the 255s looked incredibly mean!
    Dec 26 2007
    PNWR
    Frankly, I think you're better off with 245s, especially if you track. 255 is too much meat for an 8.5" wide wheel and certainly too much meat for our gutless cars. Wide tires are meant for powerful cars that need that much patch to put the power to the ground or for autox where the aim is to keep the tires glued through sharp turns at speed. Personally, I like the 235s on 8.5" wide wheel setup as the wider rim stretches the tire just enough to make it a bit more responsive. Bigger is not always better. Just my $.02.
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    very nice John. I cant wait to see the car! There is a Thursday night GTG in Irving.
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    Be sure and post some pics when you get them mounted. Did you consider running some spacers before swapping tires? 5mm would have taken you to an ET38 offset... Just a thought.
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Louis J. View Post
    x2, I completely agree with Louis here. I understand what you are trying to do, but going big is not the best option. I had 18x8.5's with a 245/40/18 and is what too much tire. The sides poked over the wheel and looked terrible. I now have 235/35/19s and I love how they grip the road. I don't think the 35 will be a problem at all because I am 25.25" ride height on coils and don't have any issues at any time during cornering, etc. The 245s should fit fine as well.
    Jan 17 2008
    Evolution X
    Texas
    Personally I like a little meat on the edges of the tires. Not "poke" outside the fenders, just a nice square look on the edges. Stretched tread looks good, but when I pay for nice wheels, I want them to be safe! The tires should be here today, hopefully before I have to head out for 4th of July festivities. I will for sure post pics, but I will be very embarrassed as my car is not particularly clean at the moment...
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Oh shit...Are you all doing it on purpose...?
    I cant see anymore of those fu*kin looking great CE28Ns...
    Gee...I cant stand watching them and drooling like an idiot...
    Rear Valence+Trunk Air Lip+Mirror Housings+WindowTrim CF'ed, Debadged Trunk, Front+Rear Red Tie Hooks, Engine Cover Removed, Painted WasherFluid+Coolant caps, Toyo Proxes Racing Semislick R888 225.40 (for now), OZ Ultraleggera 8x18 ET45 Black, 76mm Custom Cat-Back Exhaust, OEM BlackMask w/ black Audi Badge, Sparco 33mm Racing SteeringWheel, RUF Snap-off WheelHub, CF ShiftKnob, ColourMatched BrakeCalipers, APex-I TurboTimer black, Custom BilsteinPSS Coils by Kirlagkitsis Greece, Tinted Tailights, GReddy Electronic Φ=60 Warning A/F, WaterTemp, OilPress, FuelPress
    Defi BFSeries (w/ link) Φ=60, Boost, EGT, OilTemp, + 1, Custom GaugePods by XM Greece, PIAA CityLights Super White and White, Sparco CF Pedals, Simoni Racing SteeringWheel CronoMeter, Sachs Organic Racing Clutch Kit, Custom Decals, Alcantara Shift Boot, CAI, Forge 007 DV, Black HeadLights w/ Clear Corner Mod, Removed ArmRest
    Check it here
    Jan 17 2008
    Evolution X
    Texas
    I put a couple of em in my bedroom last night before bed... :)
    Jun 02 2008
    Greece
    We're just like the same...No worries... :P
    Check it here
    Jan 17 2008
    Evolution X
    Texas
    I'm still jealous of all the work you have done to your car compared to mine!
    So far I have only:
    H-Sport RS4 sways front/rear
    S4 PSS9s
    Revo 93
    Volk CE28N
    PS2
    and.. S-Line front bumper with RS4 grill.
    I've got some work to do to catch up with your amazing car!!
    Update:
    Well, went to NTB because they had the tires in (pretty speedy service by Tirerack), but they had an hour and a half wait to get them done. I have to drive out to Possum Kingdom for 4th of July weekend, and go to the airport straight from the lake for a mission trip to Panama. Long story short, couldn't wait. So, we won't be seeing these on the car until a week from this Saturday. :(
