Results 1 to 12 of 12
    Established Member Two Rings Mtepete's Avatar
    Jun 17 2008
    2005.5 A4 Black 20% Tint
    Hartford, CT
    Question about 19's
    ive never had after market rims before so this may seem like a stupid question but what ever... if i got 19's (looking at the vmr v715) would i also need CO's? would it look bad without them.. it seems everyone on here has C/O - just didnt know if it was something i needed to spend my money on with rims that large... thanks
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: Question about 19's
    Quote Originally Posted by Mtepete View Post
    No.
    Yes.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    you won't NEED them. But you do because it will look like a 4 x 4 otherwise.
    Jun 17 2008
    Hartford, CT
    are there cheaper yet good quality CO's out there other than the tein's? 1000- 1200 seems like a crap load of money but ill do it if that is the only way to go
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    If you think that 1000-1200 seems like a crap load of money check these out:
    http://www.stasisengineering.com/Cat...&VID=48&PID=90
    They'll make you feel a lot better about coils that cost $1200.
    Appearance: OEM+
    Jun 17 2008
    Hartford, CT
    looks like its time to go to the casino haha thanks guys i appreciate it i cant wait to get the rims/ CO
    Jun 05 2008
    '08 A4 2.0T SE
    jersey
    i just put 19's on w/o co's. it doesnt look bad but it would def look 100x's better lowered. ill post pics when i get back from work.
    Registered Member One Ring element498's Avatar
    Apr 06 2008
    2006 Audi A4 2.0T
    Springfield, VA
    19"s Stock
    19"s Sport Suspension
    19"s Lowered
    These were takin from the n00bie thread...
    http://www.audizine.com/forum/showthread.php?t=105668
    2006 A4 2.T Quattro | Stock (For now)!
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by element498 View Post
    19"s Stock
    4x4 mode.
    not too bad
    19"s Lowered
    FTMFW
    Appearance: OEM+
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    to the OP, i was in the same boat as you, and i didnt know shit about dropping a car either, so i will pass on the knowledge that i have learned from others on this forum..
    basically if your putting 19's on your car, you will want to lower it because it looks WAY better and without lowering your car will look like a jeep..
    c/o's are expensive, and are usually used if your planning on tracking your car or if you want a really good OEM quality ride. they are expensive because they lower your car and can be adjusted.. so lets say you put them on, then want the car higher, or lower, or just lower in the front.. etc etc you can have them reinstalled (but its expensive.. might cost $300 to install c/o's, then if you want to adjust it you will pay for another installation) most people just put them on and never adjust it.. making c/o's not much better than a spring/shock combo
    you can also just buy lowering springs, maybe cost you about $200, and then you have to pay installation.. BUT, with springs, after a little while your car will ride like shit, and your shocks will probably blow because the lower springs will be making your shocks work at a lower level that they are not tuned for and you will need to replace them eventually from all the wear
    soooo.. many people who dont want to buy c/o's just go out and buy a good shock/spring combo.. may cost you anywhere from 600-900 just depending on what you buy.. a lot of people argue and say.. "well, if your to spend $700 on a spring/shock combo, you might as well as put in a couple hundred more and get yourself some c/o's".. which is a valid argument
    basically if you search a bit, you can find some more threads on this that i probably started because i had no idea
    so its basically either c/o's, or a shock/spring combo.. c/o's are more expensive to buy, more expensive to install, and sometimes you need to maitenence them which can be pricy as well..
    if you arnt going to track your car, and you dont care about adjusting the height (most people just set it and forget it) then i would buy a new spring/shock combo and it will look SICK with 19" rims
    hope this cleared things up for ya
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by Bllzll View Post
    You don't have to remove the coilovers in order to change the height.
    Appearance: OEM+
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    I debated for a long time whether to suck it up and buy C/O or go with springs/shocks.
    In the end the recent $200 price jump on the Stasis SS C/O kit was enough to convince me to go with springs/shocks.
    Which left me with enough funding for RS4 sway...etc.
