Results 1 to 4 of 4
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    check engine light
    Just found me an 2001.5 s4. great car. my instructor just got married so he was unable to plug in my car for me. here is my small is of problems:
    The check engine light came on
    Throttle surges at high RPMs at times
    Runs rough when i start it up in the morning, but goes away when i hit the gas a few times
    The car always needs water
    hope i dont have to pay too much to get it fixed. any information will work.
    thanks in advanced for all of your help
    Dec 06 2007
    Calgary, AB, Canada
    Re: check engine light
    hmmmm, could be a whole host of different things. Bad EGT sensor, bad MAF sensor, blown headgasket, etc...
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    You gotta VAG it man.
    By the car always needing water I can bet there is a coolant leak though, lol.
    Jun 09 2008
    Lodi
    JHM is the man. He decided to VAG my car for me. We left our school and on the way to his shop he said right off the bat that my car had a boost leak. Then my car would not go into second gear. There was a crap load of play in the shifter. Pulled it into the shop and he kept moving the shifter and then the linkage fell all of the way off. Popped the hood and found the MAF was unhooked, fixed that. Dropped the transmission and replaced the linkage and installed the bushing, did a boost test. Couple hundred bucks later it was all fixed. Shifter is much stiffer and now I can’t wait to buy one of his shifters. Road in a car with his shifter, chip and FMIC last night while I was waiting for my car to be finished, AMAZING. Huge difference with stock turbos’ and not much work done to it. I was shocked because my truck had a chip in it and there wasn’t much of a difference.
