Originally Posted by
1hotA4
No one here is asking you the right questions. I have 2 12w6's in my trunk on a 1000/1 and it does wonderful.
The right question is what kinda music do you listen to?
Rap you need atleast a 12" for excursion factor.
Rock or Reggae you need a 10" because it moves faster.
Building a box for either of these subs sizes is easy to do if you are tool handy. But if not, your best leaving it up to a professional. I have worked on some peoples 'DIY' setups before and it was horrible.
As far as speakers go, You have a ton of companies out there. Jl is expensive i wont lie to you. And to do it right you need to change alot out to make it sound good. JL subs are good they can actually hold alot more then they are power rated for. If you just want some thump and not spend a whole lot. I would suggest something like JBL or Rockfosgate Power series both companies make pretty good subs. The Jl Audio 12w6 or 10w6 series isnt bad neither. But again its pricey.
Your first two statements are myths, and not true at all.
Subwoofer size has nothing to do with how fast it will be or that you need larger drivers for deeper bass. Installation is the key here, when you know what you're doing, you can use any size driver and achieve the goals you are after. Low frequency response is ruled by displacement, the more air you can displace the lower the driver can play. Basically, is it easier for an 18 to play with some authority at 30hz, compared to an 8? Yes, but can you get 8s to play just as low? Without a doubt. Yes it might take 3-4 of them to reach your desired output level, but it is very much possible.
What really needs to be asked is, do you want overpowering bass, or do you want a well balanced system?
If it's the first, a single 12 in a ported enclosure will be enough for this car. If it's the latter, a pair of 10s will do you just fine.
I currently use a pair of 10" drivers in a ported enclosure, I'm not a bass head at all, I listen to heavy metal so even this setup for my music tastes it is probably over kill, but I needed a pair to work with my amp so I went that route. On the other hand, I have probably 2-3 more money put into my front stage than I do my sub setup.
