Results 1 to 6 of 6
    Senior Member Two Rings dichiee's Avatar
    Dec 15 2005
    Vogtland club spec with koni/bilstein?
    Anyone have a pic with this setup? Is it lower than the stock sport?
    Thanks
    ## dichiee ##
    2012 A4 Prestige S-line | 2016 Fiat 500e e-Sport | 01.5 India Red A4 Avant | 04 A4 3.0QAS | 07 Passat Variant 2.0T | 02 S4 Stage II | 01 Cabrio GLX | 96.5 Jetta GLX | 99.5 2.0 Jetta (RIP 1999-2004) | 95 2.0 Golf Sport
    4th Watch!
    Veteran Member Three Rings brlukosk's Avatar
    Mar 21 2006
    St.C MN
    Re: Vogtland club spec with koni/bilstein?
    As far as I know the 'club spec' springs just have a higher spring rate in the rear, otherwise they lower the same as the standard vogtland springs. If you are planning on adjustable bilsteins (perches) you will have some flexibility as far as hight is concerned. If not your going to be stuck at a 2 finger gap all around. Any lower and your going to negatively impact handling.
    Dec 15 2005
    But it should be lower than the stock sport correct?
    ## dichiee ##
    4th Watch!
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Yep. Our Vogtland springs lower the car .75" from the factory sport height.
    Dec 15 2005
    thanks Mike
    ## dichiee ##
    4th Watch!
    Senior Member Three Rings UCFQuattroguy's Avatar
    Jul 05 2005
    '01 Audi A4 TMQ
    Orlando,FL
    IIRC the rates are 348lbs/in in front and 360lbs/in in the rear. I currently have them paired up with Bilstein sport shocks and H-Sport swaybars. It's got to be one of the better handling setups out there. The car is very neutral on this setup.
