Results 1 to 12 of 12
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    2.8 Engine Cover - Need help locating
    Came across this style of engine cover for the 2.8. According to the website i obtained the picture from, it is from a 2.8 A6. It has the look of the V8 4.2L engine cover, and i want one badly - anyone know where i can find one?
    I tried searching the forums (AZ, AF, Fourtitude), ebay.com, ebay.de, google, audi online parts stores, but no luck. I'm thinking this is a euro cover, so maybe someone from across the pond could help?
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Established Member Two Rings TJR178's Avatar
    Mar 27 2008
    Erie, PA
    Re: 2.8 Engine Cover - Need help locating
    Not a euro. I have one straight from the factory on my 2.8. Try ECS Tuning or some other parts vendor. It probably won't be as cheap as an eBay part, but they should at least have one.
    May 28 2007
    Mt. Airy, MD
    Hmmm - maybe they came on later model 2.8s then? I've only seen them with the V6 at the front of the cover
    Want to sell yours? :)
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    only difference i see is that it doesnt have the 5v badge over the valve cover sides..otherwise looks the same. and im pretty sure it is a 30v becuase its got the newer style intake mani
    2004 Subaru Impreza WRX
    Aspen White
    May 28 2007
    Mt. Airy, MD
    Here is my current cover - you can see the difference between the two by the badge located at the front, and the Audi rings at the top
    Mar 27 2008
    Erie, PA
    Quote Originally Posted by A4 Effort View Post
    Oops! My fault. I have the same exact covers as you. Nice and clean engine bay you have there! That's my project this weekend.
    Is that a K&N intake? How's the power and sound from that thing?
    May 28 2007
    Mt. Airy, MD
    ^^ Power gain is minimal - i didn't notice anything gain-wise after the install, but the throttle felt a bit peppier (maybe a certain placebo effect involved with that). But there was definitely a noticable sound difference....nothing to brag about by any means, but there was a difference.
    The only problem with the K&N 57i kit is the fact that the filter sits up so high, whereas, the e-bay kits include the piping that sticks the cone down into the fenderwell more where it belongs. I've been considering ditching this and going with an e-bay kit.
    p.s. - when you do your engine bay, make sure you grab some Mother's Back-to-Black (if you haven't already). That stuff works great!
    Mar 27 2008
    Erie, PA
    Cool. Thanks man.
    I have Back-to-Black and I agree!
    Let me know if you want to ditch the intake. I'll take it. I'm not into those chrome ones on eBay. I think I can make the K&N work anyway.
    Jan 15 2007
    san jose
    I can't tell is there a clamp on your intake hose?? i might just be the camera angle
    May 28 2007
    Mt. Airy, MD
    ^ That's not my engine. It's a pic i got from this site: http://www.electricsupercharger.com
    Senior Member Two Rings boringb5's Avatar
    Apr 26 2007
    nowhere
    The part you are looking for is off the last of the 2001 A4 2.8 V6. Here is the part # on my work computer from ETKA 078-103-927-AJ in the description it says V6-2.8. hope this helps.
    No show and No go, my boringb5 2.8
    -RNS-e with bluetooth + no clock problems
    -TT S-line Flat Bottom wheel
    -S4 Aluminum trim
    -Jhm shifter "Kit" and 034 street mounts
    May 28 2007
    Mt. Airy, MD
    ^^ Awesome!! Thanks a million my man!!
