Results 1 to 4 of 4
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    s-line badge in grille removal
    does anyone know if you have to take off the front bumper to remove the s-line badge in the front grille. or should it just pull out/clip out by putting your fingers behind there. i'm doing alittle something and i dont want to remove it for such a little mod. leave some feedback
    Registered Member Two Rings
    May 19 2008
    PA
    Re: s-line badge in grille removal
    You can remove the front part of the badge with some tools and your fingers but I think to get the back part of the clip out you will have to remove the grille. Which means you will have to remove the bumper. So if you can live with the back part of the clip in there your good to go!
    May 10 2007
    Long island
    well, i want to replace the badge with another s-line badge...so i guess i can use the clips that are already in there like you said?
    May 19 2008
    PA
    Yes...that will work... a bit of squeezing on the hands (or fingers) but it will work...
