Results 1 to 15 of 15
Thread: 120k too much?
    Registered Member Two Rings 01svtL's Avatar
    Apr 16 2008
    Houston
    120k too much?
    I'm looking at an S4 that has 120k on the odometer. It's a southern car, very well taken care of. Are these cars dependable with high miles like this? What service should I be sure is done? Any service coming up that would need to be handled?
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: 120k too much?
    t-belt will need to be done soon, if it wasn't completed recently.
    turbos could be a ticking time bomb.
    Stage 3+ RS6's
    Feb 26 2008
    washington
    Re: 120k too much?
    ive got 142k on stage 3. only been stage 3 for about 5k miles. only trouble i have had was a bad ect. like he said, t belt and turbos. if you dont know when the tbelt was done, good idea to do it.
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: 120k too much?
    you would without a doubt wanna make sure that the time belt and water pump were done. This service should be done anywhere from 70k to 100k miles, but this always isnt the case. It pays to have the car checked buy a Audi/porsche mechanic. The stock Ko3 turbos are prone to failure. If they are still original with 120k miles I would buy the car!! Most likely it wasnt beaten on and was left stock. Anyway be prepared to spend around 3,500 when they go.
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    Re: 120k too much?
    "dependable high mileage B5 S4" ha, you'll find these cars can be very temperamental, especially as a daily driver. but like everyone said, tb, water pump... turbos, historically speaking, tend to go around this age (mine did at 116k)... definitely have it pressure tested for boost leaks, an extremely common one is in the trottle body boot. in my car, all sorts of pain in the ass sensors go from time to time, notably the O2 sensors. most recently, in fact getting replaced tomorrow was a left rear wheel speed sensor... go figure. not to dissuade you though i love my car
    '17 Ibis White B9 A4 quattro P+ S-Line
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Re: 120k too much?
    Quote Originally Posted by CruzS4 View Post
    ummmmm lol
    Veteran Member Four Rings Cole's Avatar
    Dec 12 2004
    Cayenne Turbo, S6, 928S4, 951, KTM,BMW, Kawi x2, VW T4 Eurovan Weekender, Ram 2500
    Colorado
    Re: 120k too much?
    http://www.audizine.com/forum/showthread.php?t=221147
    Not if the car was taken care of well.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Re: 120k too much?
    Are there any service records with the car? I would definitely do the timing belt and everything involved with it asap. Also, if its a 6spd i would go ahead and do the clutch as well. The stock SAC mechanism on the PP sucks and has a knack for leaving people stranded. Besides that, i would check for oil leaking from the turbos and motor(especially the vc's), check all the bushings/rod ends in the suspension, cv boots, mounts, and check for brake fluid coming out of the bottom of the bell housing on the trans...which is a sign of a bad clutch slave cylinder. Im sure people will chime in for other things to look for...these are just things that were bad on my car so i know to look for them lol. Good luck man.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Apr 16 2008
    Houston
    Re: 120k too much?
    Thanks for the responses so far. I'm going to have to check and see if there are any records. I already asked him about a couple of the things you guys mentioned. He's out of town now though, so I'm waiting on a response.
    Oct 12 2006
    2000 Nogaro S4
    Hillsboro OR
    Re: 120k too much?
    my car has 106k, new turbos, water pumps, tbelt...and is GREAt and pulls VERY hard...
    most ppl are like "this has over 100k miles????!?!?!?!?!"
    2002 A4 - sold
    1990 CQ - sold (sadly)
    2000 S4 - sold (sadly-er)
    currently audiless
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: 120k too much?
    Quote Originally Posted by smithm5 View Post
    i get the same thing
    i can vouch for high mileage s4's. i say go for it
    Registered Member Two Rings bw01s4's Avatar
    Sep 13 2007
    2001.5 s4 stg II+ 911 Carrera
    plymouth
    Re: 120k too much?
    Quote Originally Posted by ThirdStrike View Post
    same here, 169k stock turbos on mine
    2001.5 S4 stg 2+
    1984 porsche 911 Carrera
    2004 allroad 4.2
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: 120k too much?
    My previous one had 175K and ran like new on original turbos. My current S4 has 138K on it and it runs good. I just got it and have a few more things to sort out but it runs solid. There are some good high milage S4's out there. I would say make sure they are hwy miles though.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    May 31 2008
    New York
    Re: 120k too much?
    Quote Originally Posted by bw01s4 View Post
    wow stock turbos...u have a chip?
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: 120k too much?
    I have 88k miles on my car and she runs perfectly well... no issues at all.
    What's the price of the S4?
    --Adam
    Have questions? E-mail me.
