Results 1 to 16 of 16
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    How do you clean the 'fuzzy' intake?
    I have tried several off the shelf degreasers and cleaners so far and that manifold still looks like crap. The best product so far was Simple Green Max... I know it's partly the texture, but I have seen some of you with some very clean engine bays... what are you using?
    I searched the detailing forum but didn't really find anything..
    Any suggestions?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: How do you clean the 'fuzzy' intake?
    elbow grease is a big factor as well.
    You want it perfectly clean, remove it and have it sand blasted.
    Paint it afterwards with something not so textured and it'll clean easier later.
    Simple green is good stuff. We had some good stuff at our detail dept until Jan 1 when the DOT banned it.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    try some laundry soap. Mine was dirty as shit and I got some sand paper that was laying around and it looks great after 5 mins
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Use wrinkle paint... A year and a half so far and haven't even had to attempt to clean it...
    ΜΟΛΩΝ ΛΑΒΕ
    Feb 25 2007
    1998.5 A4 2.0BT
    djwimbo: I think you just added a project to my winter to do list... I like the smooth intakes.. wonder what kind of time/elbow grease effort this takes...
    biketsai: any pics?
    Ewok_Fetus: You must have had to remove everything to paint properly... what a nightmare that must be?
    Feb 25 2007
    1998.5 A4 2.0BT
    Also, Ewok: how did you clean up the top of your motor? Looks pretty shiny... Mine is a mess, she was built to drive, but I want to fancy her up a little.
    Jun 04 2007
    Austin/DFW, TX
    I'll try to get a picture tomorrow. Its not completely shiny, but it looks clean.
    My 5-Speed Swap DIY
    - B6 USP
    Mar 04 2007
    nothing
    nowhere
    It honestly wasn't that bad removing the intake manifold... I am a disabled vet with some serious back/hip injuries and I got it out just fine... Took me a while but it isn't as bad as it sounds... As for the valve cover, just simple green and a toothbrush...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    aircraft paint stripper from autozone works wonders! just don't get any of it on your skin
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Quote Originally Posted by B5Burn View Post
    Could always polish your mani too to give it a nice shine..id also like to know how he was able to get his valve cover that clean, im guessing a good cleaning and aluminum polish?
    2004 Subaru Impreza WRX
    Aspen White
    Feb 25 2007
    1998.5 A4 2.0BT
    You guys kick ass, thanks for the tips. I have been asked to show this week end at a Toyo Driven To Perform event and I have just a few things that need some serious attention. My girl was built to drive, not show... but now I have kind of been bitten by the bug and want to tighten some stuff up.
    Here is the before... (sorry for the poor pic)
    I'll post an after when I get 'er all done.
    Feb 25 2007
    1998.5 A4 2.0BT
    My wastegate, the top of my motor, and any other smooth metal has some kind of oxidation... maybe CLR will clean it up... hrmmm..
    I know, that coolant tank has to go!!
    Aug 13 2007
    what pipe is that going through your firewall?
    Aspen White
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If i had to guess that's the air intake w/ the filter where the battery used to be.
    Me inspiring somebody to do some work... why does that sound like a bad idea. Another option would be to get it powdercoated. The wrinkle finish is pretty common, I'll see how I like it in person at Waterfest.
    I'll probably join that trend just b/c it's black and easy. Only difference is that I'm porting the spare one I have sitting around. That one will get painted and installed.
    Feb 25 2007
    1998.5 A4 2.0BT
    BONFIRE074: djwimbo has it right. My battery is in my trunk. massive air filter unit (plus coils) sit where the battery used to be.
    Senior Member Three Rings jlien08's Avatar
    Jun 28 2007
    98.5 A4 1.8TQT, 01 ZR2 Blazer
    Woodbury, MN
    I used Rustoleum hammered finish spray paint. It's textured, so it hides the imperfections on the IM.
    1998.5 Audi A4 1.8T Quattro Tiptronic - MagnaFlow - Bilstein - Neuspeed - EvoMS - 034MS - LLTek - FMIC - VDO -
