Results 1 to 6 of 6
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Stock DV in reverse?
    my gfb hybrid valve is leaking. for some reason the piston on the inside does not seat all the way to th ebottom of the valve so there is TINY opening where air escapes where the horn is connected to the side of the valve. So in the meantime i am going to put my stock dv back on and im not sure which way its supposed to go on. Should i put the side or bottom of the valve on the pipe connected to the intercooler pipes? thanks
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: Stock DV in reverse?
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by a4rings View Post
    The stock (diaphram) type of valve should always be installed with the side tube going to the IC pipe and the bottom is the return.
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    if installed backwards, wont it cause surging?
    2004 Subaru Impreza WRX
    Aspen White
    Sep 20 2004
    2001 a4 quattro
    Sactown
    I'v heard of people installing valvs like the 710n backwards. i installed mine backwards earlier today(boost tube comming from intercooler piping into the bottom of the valve) and it seems to be working just fine. what kind of symptoms should i be seeing?
    Jul 07 2004
    socal
    Audi installed then both ways, but it worked backwards at low stock boost. Problem is that they never last very long when installed like that because you are putting pressure on the bottom of the valve along with pressure on the top thru the vac line, this will cause the rubber diaphram to rip sooner then it would if installed the correct way. When you install it with the boost going into the side tube there is no pressure put onto the valve which means there is less stress on the diaphram. Only piston type of valves should be installed with the boost pressure against the bottom of the valve.
