Results 1 to 9 of 9
    Junior Member Two Rings
    Jun 23 2008
    Lancaster, PA
    misfire in cylinder 2! I don't know what the problem is?
    My check engine light came on and my engine started to put kind of like when a ignition coil goes out but not as bad. Has i give it more gas , just when the turbo starts to spool up, it stutters and puts pretty bad! I went to advance auto and they hooked it up to a vag-com that said their is a misfire in cylinder 2. They suggested replacing the sparkplugs. I just got done replacing them and took it for a drive and it seems worse then before. What else could be the problem?!
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: misfire in cylinder 2! I don't know what the problem is?
    If your car is pre 2000 then its the Ignition Control Module
    Another one bites the dust
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by nebone22 View Post
    yes sir, i "saved the day" for the kid up the street when his AEB misfired on cly 2 and he replaced the coil and plug... ICM
    Active Member Two Rings Bluejuiced's Avatar
    Jul 23 2007
    98 Audi A4 1.8tqm
    Westminster
    coil pack or fuel injector if it goes to lean itll miss fire also but i think you would of blown the engine if you went as lean as that with the turbo
    Oct 27 2007
    In the lab
    Quote Originally Posted by Bluejuiced View Post
    now how many fuel injectors have you seen go bad on 1.8t's?
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    yeah never seen an injector go bad.
    i would swap a coil first. if the misfire doesnt move with the coil, put an ICM on it.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    My car did the same thing. It was the coil pack. It was good as new once I replaced it.
    Registered Member One Ring MikeSammons32's Avatar
    Aug 12 2008
    1998 Audi A4 Quattro 1.8T
    Georgia
    Same thing happened to me. Replaced the coil with no luck; turned out it was the Ignition Control Module.
    Established Member Two Rings acollicott's Avatar
    Nov 13 2007
    2000 A4 1.8TQM
    Daytona Beach
    try gapping your plug down to .028 if you're chipped and .032 if you're stock
    I forgot to gap mine once and my car misfired horribly when the turbo spooled up because the spark was being 'blown out'. Hopefully thats what it is for you it makes it a cheap and easy fix
    00 A4 1.8TQM | Santorin Blue | GIAC | Forge 007P | Pioneer AvicD3 | Southbend Stage III | N75 Race | Swiss Cheese Airbox | Boost Gauge | Sport Suspension | Windows Tinted | HIDs |Custom TI Package |
