Results 1 to 7 of 7
    Established Member Two Rings myers1.8TQ's Avatar
    May 02 2008
    Silver 99.5 A4 1.8T QTip
    South Hills / Pittsburgh
    Automatic Transaxle 01N or 01V . .
    How do you know if you have a 01V transaxle or a 01N transaxle? I have a 99.5 1.8T QTip.
    Thanks,
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: Automatic Transaxle 01N or 01V . .
    Quote Originally Posted by myers1.8TQ View Post
    Thanks,
    are you talking about the axles?
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Pop open the trunk, lift the floor mat and on the right side of the spare well, there should be a build sheet with a whole bunch of 3 character codes... Look for one that says 01V or 01N...
    ΜΟΛΩΝ ΛΑΒΕ
    Established Member Two Rings Audi99's Avatar
    Jun 11 2005
    NY,Westchester
    Quote Originally Posted by Ewok_Fetus View Post
    --01V or 01N code NOT there
    same question but for
    99.5 2.8 V6 QTip Engine code: AHA, Transmission code: DRN
    VIN: WAUED28D5XA330005
    or where do I look it in ETKA?
    Thanks,
    A4 99.5 v6 2.8L 30V QUATTRO TIP
    Maintenance/repairs:
    Tires ContiExtremeContact DWS - 99k 7/11
    4 New shocks 104k 11/11
    Wheel bearing(rear/pass SNR oem) 120k 06/13
    Spark plugs 120k 06/13
    O2 sensor(B2S1 Front driver side,Bosch 13842) 120K 6/13
    GOODRIDGE SS BRAKE LINES/Fluid 126k 11/2013
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    IIRC, the 2.8 V6 Transmission transaxles didnt change from 96-01. Somebody please correct me if I am wrong.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 11 2005
    NY,Westchester
    so which one 01V or 01N?
    Jun 30 2008
    Erie, Pennsylvania
    01N = 4-speed, Front Wheel Drive, Auto-Trans for Audi 80/90 Quattro (up to 1995).
    01V = 5-speed, Front or All-Wheel Drive, Auto-Trans for Audi A4 (96+)
    There are several different transmission codes for the 01V which deal with gear ratios, final drive, torque converter stall speeds, and other differences. You should match the codes upon replacement. The code will be printed on the build sticker in the trunk.
