Results 1 to 15 of 15
    Feb 28 2006
    Las Vegas
    car carrier towing...
    I'm moving and need to tow my 2006 A4 quattro, but according to the penske truck rental site, they have my car listed as being able to tow but not with 18 inch wheels. I have the stock s-line 18" wheels. They list 265 60 R17 as being the largest size wheel/tire that can be towed. Will my car not fit on the carrier or can I still tow it? If the car fits, would it be too dangerous to tow?
    Anyone have experience with this?
    '08 Q7 3.6 S-Line
    '06 A4 6mt S-Line Quattro -*sold*
    Apr 18 2008
    Jacksonville, FL
    Re: car carrier towing...
    more as a comment for other readers of this thread and a possible reminder to the OP, any Quattro-equipped vehicle must be carried on a flatbed and cannot be towed by a standard tow truck (with two tires spinning on the road).
    so says the manual.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    It's not your wheels you have to worry about, it's quattro which means no towing.
    -Kris
    Feb 28 2006
    Las Vegas
    I know all wheels have to be off the ground with quattro. I'm getting a flatbed carrier, not a tow dolly. They say on their website that any car with 18" wheels is too large for a flatbed carrier...
    https://www.pensketruckrental.com/pe...ire_chart.html
    Has anyone towed their car on a carrier with 18" wheels or larger?
    '08 Q7 3.6 S-Line
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    the overall diameter and width of the stock 18" wheel/tire setup are almost identical to the stock 17" wheel/tire setup.
    in other words, the diameter of a 235/40/18 tire is pretty much the same as a 235/45/17 tire and both have 235 mm width as well.
    I highly doubt you'll have any problems.
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    wtf? too large for a flatbed? my mom's car has 19" wheels and it gets towed on the flatbed all time. i call bullshit
    Feb 28 2006
    Las Vegas
    Quote Originally Posted by kooltechie View Post
    That's what I thought. I just wasn't sure why they list on their tire chart that it's not within their limitations.
    '08 Q7 3.6 S-Line
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Quote Originally Posted by nahf14 View Post
    Probably the same reason why Crutchfield.com thinks that we don't have double-din dash openings.
    People are stupid.
    Jun 22 2008
    07 A4 2.0T S-Line Quattro Tip
    Northeast Alabama, US
    My car has ridden on a flatbed, and it has the 18" S-Line wheels.
    Senior Member Two Rings Raymax_2.0t's Avatar
    Jan 01 2008
    Tulsa, Ok.
    Quote Originally Posted by Technik View Post
    Same here, 18'' Titaniums.
    Active Member One Ring dadas78's Avatar
    Apr 20 2008
    Montvale, NJ
    Thumbs up Re: car carrier towing...
    Try Fed Ex. I had them transport my car from NJ to Southern California. Great experience.
    http://passport.fedex.com/
    May 11 2008
    Naples,FL
    Quote Originally Posted by supamannn99 View Post
    All the time ? thats no good what kind of audi is it ?
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    I just towed my car a few thousand miles on a flatbed trailer with my 19's on and had no problem. It was a buddies trailer so it may not be exactly the same size as the one you're currently looking at but it should work just fine. I have the cupra splitter installed so I had to put some thick logs under the back so when I put the ramps down to drive my car on and off the splitter wouldn't get ripped off with the ramps.
    Nov 15 2007
    Quote Originally Posted by Brent27 View Post
    lol.. uhh its a maserati >________>
    but still.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    give it a test fit. call them and tell them you want to try it out. I have no idea why 18 would be too bit.
    The usual things!!
    Resistor Install
