Originally Posted by
nateS4
My inner electric fan does not cut on. When I have the AC on, on a hot day the car will begin to rise above normal (2 notches) when I am not moving. If I turn the AC off the coolant temp will return to normal. I don't have a service manual yet, does anyone know where the relay is for the fan motors? I saw some relays on the drivers side, but they aren't labeled. Any suggestions??
You are talking about the fan that is BEHIND the radiator. It only runs with the A/C (except if the engine temp passes a certain threshold, iirc). There are a few possible things that could be causing this.
1. The fan itself is bad
2. Fan control module is bad
3. A/C temp switch is bad (connects to condenser under pass. headlight)
Let me ask you this, when the A/C is on does the after-run fan kick on? (fan unit in FRONT of condenser/radiator, just behind the front bumper) If so, that means that the control module is working and trying to use the after-run fan to compensate for the loss of the A/C fan. If the after-run fan is not on you may have a faulty control module.
You can also test the fan itself by unplugging it and directly applying 12v to it to see if it will turn on (apply for no more than 5 sec).
I had this same issue and ended up replacing the A/C fan. They are expensive brand new (~$230) so I would suggest looking for a used unit. I was able to use a fan from a '00 A4 that I cut the plug from and reconnected the S4 plug to the wire.
Feel free to PM or email with further ?s.
