Results 1 to 10 of 10
    Jan 30 2007
    2000 S4 stg3
    cincy
    clutch write-up please...
    Can anybody give me a link please. I cant find anything Im looking for when I search.
    thanks
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Re: clutch write-up please...
    Remove tranny, change clutch, reinstall tranny..
    kidding...
    **I have only removed the tranny when i removed my motor. I've never done it with the motor in the car.** However, here is how i would go about removing the tranny with motor still in:
    Remove shifter assembly from inside the cabin
    Remove half shafts from tranny
    Remove rear output shaft from tranny
    Remove tranny mounts
    Remove bell-housing bolts
    Remove clutch slave cylinder (on top drivers side of tranny, huge PITA)
    Pull tranny out toward rear of car, make sure to support the tranny till the "pin" comes out of the flywheel.
    Once the tranny is off, changing the clutch is pretty self-explanatory. Pressure plate is held on with 6mm allen screws around its perimeter. If you're going to remove the flywheel, you will need a triple square socket (i can't remember what size exactly).
    B7 S4 Avant
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    make sure you align the slave putting it back in...saves it blowing out on you when your bleeding it out. been there.
    Dec 06 2007
    Calgary, AB, Canada
    Buy a Bentley manual.
    Jan 30 2007
    2000 S4 stg3
    cincy
    Really Im only swapping trannys not the clutch or flywheel and I need a bently manual asap and dont want to wait to get one. is the a4 bently the same as the s4?
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by davism1 View Post
    Um well the cars have 2 completely different engines...
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Dec 06 2007
    Calgary, AB, Canada
    The S4 manual also covers the A4...I'm not sure about the version you're looking at...
    Here: Bentley manual
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    S4 tranny is not much different than a 2.8 or 1.8 tranny besides being a lil heavier, a couple bolts in a diff location and a diff exhaust setup I worked on all 3 cars so i speak frome experiance. If you have a 2.8 or 1.8 A4 manual that covers the tranny it will help but the engine on the other hand is a diff story.
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    Quote Originally Posted by The_Jerbel View Post
    Cheeper to buy it from ECS...
    http://www.ecstuning.com/stage/edpd/...tegory=Manuals
    Oct 29 2005
    10speed
    San Francisco, CA
    seriously, buy yourself a set of triple squares, and hex sockets and get to work
    - Axles
    - Driveshaft
    - Bellhousing bolts
    - Linkage
    - Slave Cylinder
    DONE
    - Clint
