I've been trying to follow the steps in this DIY for resetting the service light, (http://www.audiworld.com/tech/elec26.shtml) but for some reason its not working for me. I have a 99.5 A4 1.8tqm.
1. Insert your key into the ignition.
2. Push in the odometer reset button, hold it in, and turn the key to the first click. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
3. To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
4. Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
On step 2, I get the "OIL" indication in the display, and when I move onto step 3 and pull out on the left knobb on the cluster, I get "---" indication in the display which I assume is normal. Now I've tried this while releasing the knobb or holding the knobb out, then switching the ignition to off, and go back to 'On' like normal, but I still get the "Service INSP" indication in the display. For some reason this process isn't working for me, does anyone know if I am missing something here?
Also, I have an Airbag light on as well, from searching these forums, there's no easy fix for that one is there. I have to take it in and get Audi to look at it for $135 which is what my stealership will charge me. Is there a way that I can just reset the Airbag system and see if it comes back on?
A pic because everyone likes pics
BTW, this car will be up for sale very soon because I'm moving to Germany!!!
