Results 1 to 3 of 3
Thread: Epoxy Removal?
    Established Member Two Rings audinoobs4's Avatar
    Nov 07 2007
    Chicago
    Epoxy Removal?
    Hey guys i ran into a small problem. A while back when i was washing my car in the winter at the car wash(not the automatic, the diy spray kind) my rings on my trunk fell off. Ive waited til it got warmer out to try and use epoxy to put the rings back on. When i did it after the epoxy was suppose to be dry it started falling and smeared epoxy all over the area. Does anyone know how to remove epoxy without ruining the surface???
    May 31 2007
    Montreal
    Re: Epoxy Removal?
    ouch.
    I know that you can clean epoxy if not dry with Final Wash. But since it's all dry now, I'm not sure if there's something strong enough without harming the clear.
    I'll let someone chime in, but otherwise I rather wet sand the area than using a chemical that can harm my clear.
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Re: Epoxy Removal?
    Sounds like either way your going to harm the clear around it...even you use a harsh chemical and get it on the existing clear coat, its going to ruine things. Try nail polish remover, but just on the Spot where the expoxy is...use a Q-Tip. If that doesn't work, wet sand it. If you dont know how to do that...take it to a professional that does...goodluck!
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
