Results 1 to 8 of 8
Thread: Exhaust Rattle
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    Question Exhaust Rattle
    The past month or so I've had a really annoying rattle I'm guessing from my exhaust whenever I hit exactly 3200 RPM, in any gear, even neutral while not moving. I have no idea what it's coming from, the bolts from my turbo to cat are tight, my cat is solid, I whacked it a couple of times and got no rattle, my flex pipe is loose but the pipe underneath is intact, and there is no heat shielding intact with any part of the exhaust. I brought the car to a shop two weeks ago and they said that while up on a lift they didn't find any problem, but they only looked at idle. Here's a video I took, you can hear it pretty well right after the turn, I tried to hold the RPMs steady.
    http://video.google.com/videoplay?do...99330192081847
    What the hell could be causing this?
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Exhaust Rattle
    It could be touching a heat shield...
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Mar 29 2007
    Is the street.
    Re: Exhaust Rattle
    Quote Originally Posted by Bic-Ball View Post
    nop
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Exhaust Rattle
    my heatshield rattles when I am accelerating. Just check it.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Exhaust Rattle
    does the "rattle" vibrate your call at all, can you feel it in your butt? or is it just a noise
    Mar 29 2007
    Is the street.
    Re: Exhaust Rattle
    Just a noise.
    Nov 19 2005
    WA
    Re: Exhaust Rattle
    I bet you it's a loose heat shield. I'm not saying yours is touching anything, just that it's loose.
    When I had my exhaust put on, on a cold start at about 2.3k RPMs I'd get a weird droning noise. It went away after the system warmed up, so I figured the shield must be loose, and when it warms up the heat expansion fixes it.
    Got under my car and torqued down ever bolt I could find, even had to bang some spots in because they had started to pull away from the car.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: Exhaust Rattle
    have you checked the bolt that bolts from your d/p to the tranny?
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
