Results 1 to 8 of 8
Thread: clutch break in
    Mar 14 2007
    MN
    clutch break in
    whats the best way to break in a clutch? I will be going on a road trip about 500 miles total. Would it be ok for the clutch?
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Re: clutch break in
    Your not supposed to do all the miles on the highway , mix it up with half highway half city driving for proper clutch break in
    2010 Brilliant Black/Magma Red S4
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: clutch break in
    What I was told the best way to do it is to do a lot of city driving and do as much unnecessary shifting as possible. It also depends on the type of clutch that you got too. If you have a Kevlar clutch those are much more delicate for the break-in process. You need like 500 miles at least of city shifting.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: clutch break in
    op what kind of clutch did you install?
    Mar 14 2007
    MN
    Re: clutch break in
    clutch master stage 3...would it be bad to drive it on a road trip? I mean I would probably get atleast 100+ miles on it before I left for it then about 250 there with lots of city driving while im there then 250 back
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    Re: clutch break in
    Quote Originally Posted by mthomas141 View Post
    i did the same but didnt count my highway miles against my 500 mile break in. i only counted city miles. im sure some would say over kill but clutch feels great with no slippage.
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    Re: clutch break in
    I had 100 city miles on mine, then I took a road trip of about 650 miles and then did another 200-250 city miles. My clutch works great with no slippage or anything. I wouldn't stress on it to much. Just make sure you mix it up the best you can for a while.
    Dec 06 2007
    Calgary, AB, Canada
    Re: clutch break in
    Quote Originally Posted by volks88 View Post
    Alias is correct, city miles are what successfully break in a clutch. If you're going to drive highway, do what this guy did and only count the city miles towards the clutch break-in.
