Results 1 to 40 of 57
    Senior Member Two Rings treemolecule's Avatar
    Jan 13 2008
    04 1.8TQ6M(^^sleepy car)
    Charlotte, NC
    SouthBend Clutches
    I want to upgrade my clutch and I was just just curious if anyone had any feedback on the southbend clutches from www.034motorsport.com
    I wasn't looking at anyone in particular but i drive a stage1+ 04 a4 6 spd, gonna upgrade turbo soon, but thanks in advance
    [B]APR Stage 1+ and Snub Mount
    034 DensoLine Engine and Tranny Mounts
    GReddy Turbo Timer
    Forge TIP (RED)
    Buncha motorcycles
    Memphis, TN
    Re: SouthBend Clutches
    i have their stage 5 FE clutch disc with SS pressure plate... very happy with it.
    APR Stage 2/AWE Intake
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by Papachristou View Post
    Same here. So far it's holding. We'll see if it'll handle a trip to a 1/4 mile track better than the OFE SS did.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    have had 2.
    blew my stg 4 OFE clutch. had probably ~25,000 miles on it. but one too many 5k rpms launches
    now i have the stg 5 FE. happy with it so far. i mean, it works i guess. but i haven't beaten on it at all to really tell.
    very little bad reviews on southbend products
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Bought a stg3 for my B5 and works well and ill be buying a stg4 for my B6 in the next few weeks.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by HIERLEVELZ View Post
    Skip stage 4 and go directly to stage 5.
    Appearance: OEM+
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Everyone goes to 11 right off the bat. I have to wonder sometimes.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    how is the stage 5 for daily driving? is it really stiff?
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by whiteUSPflow View Post
    Feels the same as a stage 4.
    Appearance: OEM+
    Dec 25 2004
    Earth
    I'm going to phone SB, and ask'm if they use the same pressure plate(SS) for the stage 4 & 5.
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by MikTip View Post
    They do.
    Stage 4: OFE SS
    Stage 5: FE SS
    SS pressure plate for both setups.
    Appearance: OEM+
    Buncha motorcycles
    Memphis, TN
    tgrclaw has it nailed... im going to break it down fo ya!
    FE is the clutch disk...feramic (this material grabs better, wont tear like organic and dissipates heat much quicker
    OFE is the other clutch disc organic-fermaic (one side is organic the other feramic)
    SS is the heavy duty pressure plate to help with the higher friction grabbing power clutch discs have.. its a 50lb pressure plate vs the stock 30.
    Soo put them all together and what do u have? FE SS or OFE SS! compare to the OFE HD they offer which uses the similar to stock pressure plate (HD)
    Now onto driveability... both the OFE SS and FE SS will require the same pedal effort to push it down the only difference is the FE SS will "grab" quicker so its a tad trickier to drive but i picked it up really quick not to mention my 115lb wife didnt have too much trouble either! so if she can do it, anyone can...
    also to note, i got used to the pedal effort really quick too.. the first day i thought i was going to hate it but a day later it felt just like stock...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I think those #'s are way off. Most high clamping pressure plates are around 2200 lbs, I run a dual diaphram pressure plate that is 4800 lbs. So it would be hard for theirs to be rated at 50lbs and 30lbs. Maybe you meant 1300 lbs which IIRC is the rating of the OEM pressure plates.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    It is very possible that the FE won't hold the power I'm making combined with the aasco 16lb steel fly. I have launched a couple times and held the power and have spun the disc going into 2nd a couple times while launching. This was with never rev'n past 5000rpms for the launch. During normal driving it's perfect though. Even my audi tech buddy couldn't use it on his 460chp B5S4 and had to go with a 6 puck to launch it. I even have the tapered surface of the PP ground flat so there was "virtually" no break-in.
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Well that's lovely. If my FE SS blows up the way the OFE SS blew up (drag strip) I'll be saying goodbye to SB.
    Appearance: OEM+
    Jan 13 2008
    Charlotte, NC
    thanks papachristou, i know i want OFE SS i just dont see too much importance for a full feramic disc, i also wanted to ask if i throw a 16lb flywheel on there, am i beatin a dead horse or will i actually launch?
    GReddy Turbo Timer
    Forge TIP (RED)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by CO AVANT View Post
    ru-ro I hope my OFE will be okay but something tells me it won't last too long if I start launching the car.....
    The ONLY time the increased pedal pressure bothered me was driving around in Manhattan for an hour in stop-and-go traffic. But I did have fun setting off car alarms [with my exhaust] rolling around in 2nd gear at 3krpm
    -Doug
    Feb 12 2004
    Everywhere
    You will launch but you will get chatter at idle with ac on. SB has a 20LB LW fly option that might get rid of more chatter over the 034/Spec/Aasco 16lb. The FE is VERY driveable. I would not even chance on the organic discs anymore with over 300chp.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I wouldn't have the AC on. In fact, I rarely have it turned on.
    We'll see how long the organic disc lasts me
    -Doug
    Buncha motorcycles
    Memphis, TN
    [QUOTE=mike-2ptzero;2670120]
    QUOTE]
    sorry i miswrote that.. 50lb pedal effort!
    i thought the FE SS was rated for over 500hp? time will tell with some of you getting up there in power
    Feb 12 2004
    Everywhere
    well if the high elevation under powered B6 and B5S4 can't handle it I don't know what to tell you. I do know that I make over 300whp uncorrected up here now. I don't think it will necessarily fail on me but it will spin sometimes if I launch it.
    Jul 07 2004
    socal
    Actually you mean 50% increase.
    That power rating is while rolling, not while launching.
    Sep 17 2006
    SLC, UT
    ^and it's rated in torque. not horsepower
    Quote Originally Posted by Tgr_Clw View Post
    you and me both.
    Current:
    Previous:
    Jan 13 2008
    Charlotte, NC
    mike, gimme a week or two and i'll pick up a OFE SS stage 4 from your shop, funds are ridonkulous now
    GReddy Turbo Timer
    Forge TIP (RED)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Chris was referring to the force required to fully depress the clutch pedal to the floor. The stock pedal pressure is 29lbs. The Southbend SS pressure plate requires 50 lbs.
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    i love mine but go direct to southbend and tell them your setup and they will point you in the right direction. no need to go through a middle man becuase price goes up and if you run into a problem it will take that much long to resolve.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Buncha motorcycles
    Memphis, TN
    thanks fletcher, long time no see... u still got the audi?
    Jul 07 2004
    socal
    I have never seen or heard of anyone using that and I have been dealing with A4 clutch setups since 2001. Usually I just hear people using clamping force #'s of the actual pressure plate.
    I would hate to see what it is for my setup. It is very hard to hold the pedal mid way up for more then 30 seconds.
    Jun 30 2007
    Raleigh, NC
    truth. my OFE HD ate shit on a launch (dumped on the upswing to 4500) with my GTRS... spun 1 2 and 3 letting off the gas more and more each time trying to catch the clutch. (this whole process took about 20 seconds lol)
    long story short, FE SS ftw - 6puck ftmfw
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Established Member Two Rings member's Avatar
    Jan 14 2005
    San Francisco
    i had a southbend clutch, u can ask the guy to have one side be "softer" for a better pedal feel and the other side be "harder" to handle power. thats what i exactly what i had
    Member since 2004.
    2020 BMW M340i - 382hp - E-Diff - ZF 8AT -
    Dec 28 2006
    Western Maryland
    Well it's still in the family so to speak. My son is driving it. Now that he is home from college for the summer I still manage to get a cruise in every once in a while just to "check things out"!
    Dec 28 2006
    Western Maryland
    Hi Mike. That was never intended to be any sort of performance measurement. The reason I originally posted that information was to give people an idea as to the difference in clutch feel between the HD and SS pressure plate. It is fairly significant. In fact it is one of the reasons why my son is now driving the A4. The additional force was causing me problems with my knee and I didn't feel like changing the clutch out again for a third time. (Plus he needed a car since his crapped out!)
    Cheers!
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Southbend conrols the market for clutches on our cars...
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by audipotential View Post
    is it a conspiracy?
    Jul 07 2004
    socal
    Cheers!
    Good to know. So basically it almost doubles the pedal pressure. How did you get the measurement? It would be cool to see how much pedal pressure is needed for my setup I run on my car.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Strange. I've only got a Stage 3 and it's held up to repeated 5k launches just fine. And pedal feel is totally stock.
    Jul 07 2004
    socal
    Quote Originally Posted by skeeball View Post
    How much power do you make?
    Sep 20 2006
    Baltimore
    That's a fair question that I don't really have the answer to. I would say it's slightly more than Roman's car though, which is why I made the statement. I'm surprised he broke his clutch. I suppose his torque spike is much nastier than mine though.
    Veteran Member Three Rings -Audi_tuning-'s Avatar
    Jan 15 2007
    97boxster/08 A4/10 A8L/09Q7/04 S60R
    Nashua
    is it wierd that my stage three southbend feels like its going out after 10k lol? i wish i had just gone rs4...
    -german_tuned-
    2 low 2 go
    Bag Riders... the only way to do air
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    8 "1/4 mile" runs back to back will do that.
    No cooling down in between.
    Appearance: OEM+
