I've already searched the forums on the infamous P0171 - Engine Running Lean (Bank One) code and came up with a lot of things specific to the A4 and honestly a long list of things that could be bad. My car isn't under warranty anymore either.
I've got an 04 S4 with only 49k miles on it and its been intermittently throwing this code. It'll go on and off between tanks of gas.
The symptoms began when I ran the tank down to the gas light and then the check light came on about 30-40 miles right after I filled up again. Every time, if the gas light come on, the never fails, the check code appears. I figured, ok, i won't let the gas run down and then no light. Well, as of last week, light came on at 3/4 tank.
The car has been getting pretty horrible gas mileage as well. I am the second owner of the vehicle and when I first got it at 39k i was getting a good 18mpg average. Now i'm driving like a granny and lucky if i can eke out 14mpg. Im thinking the lean condition is causing my engine to run rich.
Anyway, I've read that the major things here are either a bad MAF or a vacuum leak. Any suggestions and/or the vacuum diagram for my S4? (the one under the hood is not really readable & peeling up)
Thanks in advance guys.
