Results 1 to 12 of 12
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Would you guys replace these ko4 inlets? Pics inside.
    So i picked up these ko4 inlets and they ended up and have 2 small dents/dings in them. There is no cracks in anything like that, only thing it would do is change the air flow slightly, if at all. Would you guys replace those 2? Only paid 365shipped, so not that upset. Sorry the pics aren't the best..camera phone FTL.
    http://s236.photobucket.com/albums/f...rent=mail1.jpg
    http://s236.photobucket.com/albums/f...rrent=mail.jpg
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Would you guys replace these ko4 inlets? Pics inside.
    They shoudl be fine.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    Yeah mine looked like that when i got mine off ebay also, I have a pipe expander that I put in the inlet and pushed it out, cause i am anal about that. I think any auto parts store has them for like 20 - 25 dollars if you really want to do it. But as JDM said you should be fine.
    2000 s4
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    those pipes are worthless. ill take them before you throw them in the trash though.
    Feb 28 2007
    chicagoland
    Go to autozone they rent out the pipe expanders for free if your gonna be picky
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    They will be fine. If anything, you'll need to bend them anyway to make them fit. Mine did, the 034 replicas.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Did you buy them from me?
    Stage 3+ RS6's
    Jul 17 2004
    Quote Originally Posted by tike0rz View Post
    You had to bend your 034 pipes to fit?
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Apr 17 2007
    B8 A5
    Quote Originally Posted by lil' is 300 View Post
    Not me personally, but the shop says additional fabricating was required. I'm going to ask them more about it today when I pick up the car. Make sense because I got a great deal on the pipes, and thats just my luck. I didn't end up getting such a great deal after all.
    Registered Member Two Rings Skydive@AI's Avatar
    Mar 14 2008
    Audi S4 Avant, GMC Syclone.
    Woodland Hills, CA
    Quote Originally Posted by AB18 View Post
    Ummm... you might want to test fith those pipes before you go removing those "dents". At least one of them is there for clearance, and comes that way from the factory. (If you remove the "dent" you might create an interference fit.)
    Here's a photo of a new lower left with the identical dent:
    I think the other pipe you pictured is the lower right?
    -Michael
    Jul 17 2004
    So much for 034 RS4 replicas being "bolt-on"... Shoulda went with GenJDM's cheaper aluminum pipes...
    Alex
    Dec 17 2004
    US
    Quote Originally Posted by Skydive@AI View Post
    -Michael
    This is the type of response i was looking for. Thanks Michael, i am not sure which pipes are what as i haven't pulled my engine yet and im not familliar with them. The other ding is really minor, not sure if its there for a reason or not, kinda doubtful though.
