Results 1 to 11 of 11
Thread: cat rattle
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    cat rattle
    anyone know if my internals in my cat are rattling, would that throw a cel?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: cat rattle
    I don't think it will throw a CEL. My HFC came loose and I never had a CEL.
    You sure its the cat and not the exhaust piping rattling on something?
    -Doug
    Sep 20 2004
    Paradise Valley, AZ
    Re: cat rattle
    ya pretty sure, i had it on the lift and i checked the whole exhaust and heat shields. also checked the both intercoolers. and i replaced my motor mounts and snub.
    the rattle is most noticeable in 2nd and 3rd gear. for example as soon as i shift into 3rd, i give it gas and about 2 seconds later i hear a quick rattle. after i hear the rattle, ill coast (still in 3rd gear) and let the rpms go down, then ill accelerate again and 2 seconds later ill hear the rattle again. only happens in the beginning of acceleration in 1st, 2nd & 3rd gear. i kinda was hoping it was the internals inside the cat, cuz that's the only thing left covered under warranty.
    im wondering if Audi will attempt do fix it w/out a cel?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: cat rattle
    I heard mine around 2500-3000rpm. I also had a 3inch downpipe with High Flow Cat. I went to a 2.5inch downpipe with HFC and have had no problems. The thought there being the 3" downpipe had a lot of backpressure that blew out the cat since my entire exhaust is 2.5".
    -Doug
    Sep 20 2004
    Paradise Valley, AZ
    Re: cat rattle
    thanks. i know the cat is covered for 8 yrs 80k miles. i think im gonna take it to the dealership and hopefully they can look at it and if it is the cat, hopefully they will replace it even though it is attached to an AWE exhaust.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: cat rattle
    Quote Originally Posted by diztek View Post
    Those are the exact symptoms my old Jetta had when the cat busted. Like you said - it was the last thing remaining under my warranty!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    Re: cat rattle
    had the same symptoms.
    mine was under warranty, no CEL, and the stealership replaced loose/rusted exhaust mounting hardware:
    silencer -- part#:8E0-253-609-KD AU
    clamp -- part#:1H0-253-141-B AU
    hope this helps
    Sep 20 2004
    Paradise Valley, AZ
    Re: cat rattle
    hey thanks. it ended up not being the cat. ill have to check out the parts you mentioned. much thanks.
    Nov 10 2005
    Philadelphia
    Re: cat rattle
    did you ever get a solution?
    Mar 27 2008
    Denver
    Re: cat rattle
    Haha, when I installed my test pipe I shook my cat around and I could feel the internals moving around, I never tripped the MIL though. I think clogging will trip the MIL more then this. The cat can still work if its a little loose/split internally, I feel like most of the dimples (Whatever you want to call them) will still do their job.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Re: cat rattle
    My cat was replaced by the dealer when i brought it in to find out what was rattling under the car. The cat has disentegrated on the inside, haha. I have a TP now.
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
