Results 1 to 33 of 33
    Senior Member Two Rings FLASHMSTRC's Avatar
    May 21 2008
    Arlington,VA
    Coil Pack Install/Question
    So I blew two coil packs this weekend. CEL came on and I'm reading codes P0300, P0304, and P0306.
    I went to Audi of Tysons this morning and picked up 2 new coilpacks at $43.33 a piece. Tried to pull them out myself and change them, but haven't had any luck. Is there something special I need to know about the 3.0 engine (B6)?
    Also...the guy at the dealership said I should change all six at the same time or they will keep blowing like a domino effect, anybody agree with that?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Coil Pack Install/Question
    post a pic.. They should unclip from the harness and pop staight up..
    May 21 2008
    Arlington,VA
    I'm actually having more trouble getting them away from the engine.
    They are in their pretty tight and can't get a good grip...any special tool needed to pry them up?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    not that I know off, perhaps a flat head screw driver and a small block of wood for leverage
    May 21 2008
    Arlington,VA
    How about changing all 6 at one time...do people with 1.8T's change all 4 at once?
    I guess it could just be preference.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    not sure on that, I replaced one and none of the others failed... Then I replaced all 4 before I went Giac Fx..
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I know it is wise to keep a spare in the trunk.. Perhaps in your case 2..
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    you can get them really cheap online man. I think I payed $100ish for 4.
    once you take of the two bolts holding them in they should just pop right out. like pondside said try a flat head to help you out...
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Oct 15 2006
    From a few to one...
    Arlington, VA
    i changed only 1 when it blew, and have been fine for almost a year now. i do carry a spare in the trunk. if u can wait till wednesday and make it out to the tysons meet, i can help u out. but like pondside said, its pretty much unclip and pull straight out.
    it may take a bit of effort, but its as simple as pulling straight out. i used a flathead for leverage, and gloves help a bit if ur motor is still hot.
    klum00: the boltdowns were only the b5's. b6s/b7s have the cp's that u just pop in and out.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    May 21 2008
    Arlington,VA
    I looked at the bolt and can't tell what pattern that is...anybody know?
    I mean I just tried again to just pull it straight out and don't feel it budging at all really.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    unless you have Heitachi E coils, those bolt down...
    May 21 2008
    Arlington,VA
    The bolt/screw I'm seeing isn't near the actual coilpack, but more along the line that runs along all the coilpacks. I guess you could say keeping them all together?
    Is it necessary to remove that?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    on my E style it is a metric allan bolt.. If it has more points it is a torx, not sure why you would have those..
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I'de say no... Can you post a pic?
    May 21 2008
    Arlington,VA
    I would but I'm at work...let me see if I can find a camera somewhere.
    May 21 2008
    Arlington,VA
    I took a cell phone pic...anybody here know how I can upload it to the forum?
    May 21 2008
    Arlington,VA
    Quote Originally Posted by Klum00 View Post
    Yeah I'm all about getting them cheaper online, but my car has been running like this since Saturday and don't really have time to wait for the shipping, etc.
    Where should I apply the pressure with the flat head?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    at the base between the valve cover and coilpack..or under the connector portion..
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    you did unplug them right?
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Flat head screw driver should work for you. You don't need a special tool. From reading the threads you should replace all at the same time. That way they are all new and installed at the same time.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 21 2008
    Arlington,VA
    Reading the DIY it looked like you pull them from the engine first, then undo the clip...
    Do I undo the clip first?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    yes undo the clip first..
    May 21 2008
    Arlington,VA
    I can't figure this shit out....got the coil pack lifted up partially but it won't go any further...it's connected to red "piping" and it won't move...
    Anybody in the B6 world have a DIY for the 3.0?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Your coil pack looks like this...
    Different color for your than the 1.8 but same design... it just pulls out if the connector is removed like this picture
    May 21 2008
    Arlington,VA
    Yeah I see the coil pack, no issue there. The problem is getting it away from the clip since their is absolutely no budge or room to pull it away from the clip.
    I really feel like I need to unscrew something to loosen things up a bit.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    On mine there are these push in wire holders every couple inches that you can pop out and push back in... try gently pulling those up to give you more room to disconnect the coilpack..
    May 21 2008
    Arlington,VA
    I may opt to take it to the dealership since I only have 25K miles on the car...has anybody around the area had luck getting these replaced under warranty?
    If so, how should I word it to the service dept.? Just tell them I have two coilpacks failing?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    They will scan your car and replace them at cost I believe, they aren't covered under the warranty IIRC.. I could be wrong though
    Veteran Member Three Rings swizzchard's Avatar
    Jul 28 2005
    05 B6 A4 1.8TQM USP
    Ellicott City, MD
    why don't you take a picture? it's really easy.
    May 21 2008
    Arlington,VA
    I would if I had a camera, but I don't...just need help getting the coil pack unclipped...
    May 08 2007
    Orange County, CA
    Coil packs are covered under factory warranty and CPO if you have. Warranty will only replace the bad pack though, not all 6. I had one go, then another a month later, none since. So if you want to do some preventive maintenance its at your cost. I'm under CPO now so when they went I just paid outright cuz part and labor was $45 each time vs. $50 deductible for CPO warranty.
    May 21 2008
    Arlington,VA
    CPO an extended warranty?
    Also, where is the cheapest place online to buy coilpacks for spares?
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    certified pre-owned.
