Results 1 to 10 of 10
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    So who has changed their rear diff before?
    My differential is about to explode into 1000 pieces....I know it! so i'm thinking about replacing it myself (the entire rear assembly). I am a hands on guy and know how to work on cars, plus the bentley dvd will walk me through and honestly it does not look hard to do. But please enlighten me
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: So who has changed their rear diff before?
    -Doug
    Buncha motorcycles
    Memphis, TN
    easy to pull out and replace... i opted for the stasis diff but now some guys have DIY deal for about 1/3 price of stasis...
    6 allen key bolts to take the rear driveshaft loose, then another 6 or so torx around the torsen housing... pull it off and replace
    APR Stage 2/AWE Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Papachristou View Post
    The OP is referring to the rear end differential. Not the center differential.
    -Doug
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    What makes you "know" the rear diff is about to explode?
    -Darrick
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Capt. Obvious View Post
    He hears the 'ticking'
    -Doug
    Jan 03 2008
    Columbus, Ohio
    it's making the same "clunk" noise my jeeps rear end did right before it took a dump on me. I can reproduce the noise im hearing in my cabin by turning the drivshaft while out of gear, when I turn it and the rear catches it makes the same clunking noise. Oddly enough it only happens while im turning and accelerating either direction. it happens at lower speeds and the rat of clunking matches the speed of wich the wheel would make a full revolution. Obviously I could be wrong but everything looked good underneath, no loose parts and the axles were sealed (cv) and sway bars was tight so unless you can come up with anything else (other than a endless sentence lol) im calling the rear diff.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
    Jan 03 2008
    Columbus, Ohio
    Thank you!
