Results 1 to 9 of 9
    Established Member Two Rings A4UDIRULES's Avatar
    Jun 09 2005
    Audi A4 B6 1.8T CVT
    where it never snows
    S line Steering wheel with pedal shifts for A4 b6
    Does any one has the part number for S line 3 spoke steering wheel with pedal shifts? My car does not come with multi function steering only shifter buttons on each side. Is there any other better alternative?
    Catch me if you Can!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: S line Steering wheel with pedal shifts for A4 b6
    There is none...you can get a three spoke with thumb buttons for the TIP (about $420).
    What is the color of your interior, I will post up the part number for you.
    You can retrofit a R8 steering wheel with paddle shifts and multifuntion, because the airbag is different and you will need the correct control module and cancellation ring, cost is about $1700 for everything.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    You can also retrofit a B7 steering wheel, or a TT steering wheel, using the same parts as the R8 or RS4 wheel conversion.
    -Tim
    Jun 09 2005
    Audi A4 B6 1.8T CVT
    Quote Originally Posted by 400HPA4 View Post
    my interior is black. 1700 together with the airbag? and the multi function feature will work? currently i only have thumb buttons for the cvt.
    Jun 09 2005
    Audi A4 B6 1.8T CVT
    Quote Originally Posted by sandspeed View Post
    yeah my original idea was to retrofit b7 steering wheel with pedal shifts but i didn't know i can retrofit R8 steering wheel.
    Any idea for the part number on b7 steering wheel with pedal shifts? Will the multifunction feature work on the car which came without multifunction feature? Will i need to change the airbag?
    thanks
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    R8 steering wheel is actually less expensive than the RS4. It is also less expensive than the MKII TT multifunction.
    With a B7 steering wheel, you can get the multifunction will work if you get the correct slip ring and control module, no your existing airbag will not work, you will need to get a new one that is B7 specific.
    The B7 has a dual igniter airbag, the B6 has a single, you can connect the B7 airbag up in the B6, however nobody that I know of has actually tested to see if it works (hit a pole or something).
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    hijack, what steering wheel(s) would need no retrofitting, i have a b6 2004 with like gay plain steering wheel no buttons at all. i want to look cool to my lady frinds with buttons.. tip and audio maybe.. any prices and/or part #s is appriated.. p.s sorry for the hijack
    Jun 09 2005
    Audi A4 B6 1.8T CVT
    well RS4 is out of question as my car is AUTO not manual. R8 wheel looks great and if i can get the multifunction feature work thats fantastic. so the price includes everything i.e. airbag and control modules? How difficult it is to install? Can i see the pic of this particular wheel? can nego the price?
    Jun 09 2005
    Audi A4 B6 1.8T CVT
    Do you have any pics of the r8 steering wheel? I am also looking for pedals set for Auto. Do you have that as well?
