Results 1 to 13 of 13
    Senior Member Two Rings DSM 2 Avant's Avatar
    Jan 02 2005
    B5 S4 Front Bumper - NYC
    I'm taking offers for a used B5 S4 Front Bumper and reinforcement (not in pics).
    The person I bought it from started the RS4 mod. So far the center bars have been removed and the edges were filled.
    It also comes with the original grill inserts and enough expanded metal mesh to finish the mod. The mesh for one of the side grills was already cut. You'll need to source the washer covers and fog lights.
    There's also a 2 1/2" crack at the very bottom where it ends. You won't notice it once it's installed though. It should be really easy to fix. I also don't think there's any risk of it spreading so you should be fine if you choose not to repair it. The entire lip is still in one piece.
    B9 S5 SB | B8 S4 | R.I.P. 2001.5 A4 Avant
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    Re: B5 S4 Front Bumper - NYC
    link doesent work
    2018 Mercedes GLC 300
    Jan 02 2005
    Thanks, link fixed...
    Senior Member Two Rings MassS4B5's Avatar
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    i have a brillant black car and my bumper is damaged badly how much are you looking for i need a replacement asap
    Black S4 6 speed
    Vast built motor w/ cams, valve springs, rods, clutch fan delete, electric fan, tial 650's, rs4 ic's, x-1 intake, cm stage 4 clutch, light weight flywheel, hb dv's, efu 4u, zoldman 02's, avalon ock, stasis track sports, stasis motor mounts, oem trans mounts., asp tsb, asp 3" down pipes, asp true dual
    Established Member Two Rings lakersrl's Avatar
    Jun 18 2008
    Riverside
    pm sent
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    pm sent
    Jan 02 2005
    All PM's replied.
    Registered Member Two Rings your moms wagon's Avatar
    Sep 14 2007
    2001 A4 Avant
    lost in the woods
    you have PM
    avants
    Senior Member Two Rings S4stageIII's Avatar
    Dec 07 2006
    2013 Audi S6 stage 1 & 2001 Audi S4 AWE stage 3
    G-Burg, MD
    you have PM...
    Nogaro S4..
    (AWE RSK04, Milltek DP, 710N, AWE intercooler, APR bi-pipe, APR snub, ASP DTS, Stasis Street, Neuspeed exhaust, ECS pulley, ECS stage 3 BBK, E-codes, RS4 bumper, AWE vented hood, etc...)
    Jan 02 2005
    PMs replied...
    Jul 02 2008
    Collegeville, PA
    PM sent
    Jan 02 2005
    Sale pending...
    Jan 02 2005
    Sold!!!
