Results 1 to 9 of 9
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Under Hood Question -
    anyone do anything cool under their hood... like literally the underside of the hood?
    My padding (I'm guessing heat resistant to save the hood paint) is falling off at certain spots since the clips are broken
    anyone ever replace this or do something cool in its place?
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Re: Under Hood Question -
    I have seen a few cars with a mirror like material under the hood and it look cool because when the hood is up it bounces your line of sight down onto the engine.
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I had the same problem with my hood insulator as well. So I just threw it out.
    Oh, and I remember reading somewhere that AUDI actually calls that padding a "Engine sound dampner" (or something along the lines of sound deadener.) I have had it off for several months now and no problems at all with the paint on the hood....it does get quite hot though....quite alot actually
    -Sami-
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    yeah i figured it was sound deadening as well.... the mirror thing may be cool.... i'll look into that
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    I would be so reluctant to remove that insulation pad...
    I had a 5.0 Mustang years ago w/ a set of headers and no underhood insulation. The sections of the hood directly over the headers slowly discolored/faded due to the excess heat. I can't imagine our turbos would be any cooler than those headers...I think the factory knew what they were doing w/ the insulation there. Just my $.02...
    Sep 23 2006
    Houston TX
    You'll probably be ok. I've had mine out for a year with a very warm supercharger just underneath. no discoloration yet and actually cools the engine bay better. turbo might be warmer, but I believe is farther away from the hood.
    Edit: yeah you BT guys might need to keep a closer eye on it depending on turbo placement/size
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    i dont think I would run without it for long... i think it would be a more temporary/show thing
    Veteran Member Four Rings traf818's Avatar
    North Hollywood
    My A4 didn't have the padding under the hood.
    -Ralph
    F10 550i M-Sport
    Senior Member Three Rings BlaQ_B6's Avatar
    May 20 2008
    02' a4 1.8tQ
    Jersey
    I took mine out, it's just a sound deadener. Jettas came with the same thing. I like hearing the sound of my engine xD.
    02' A4 1.8TQ
    Clear Cornered - Blacked out Grills - Stealth bulbs - 6000K DDM HID Kit - Independent Fog Mod - Debadge
