Results 1 to 3 of 3
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    brake light is flashing...
    hey guys so as you might know ive been working alot on my car putting it back together. I got a V checker code reader thing from ECS and cleared all my codes. How ever i was unable to check and clear the brake codes. dont know why... anyways my ABS light and the BRAKE light are on. The ABS stays on while the BRAKE light flashes. I replaced all the brakes and rotors with the pads that have the sensors in them and went to start it up and its still on and flashing.
    What do i have to do to get those lights to turn off?!?!
    TIA
    Its a 2000 A4 1.8TQ auto
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: brake light is flashing...
    ABS Module = K.O.
    That or one of the ABS sensors in the wheels, but most likely its the ABS module.
    Future reference, please search, this is a common problem.
    -18 718 GTS
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    I had the same problem. I would get 3 beeps at start up, as well as the abs and brake light flashing on the cluster.
    I had my abs module fixed by bbs reman.
    Hooray for boobies!
