Results 1 to 7 of 7
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Squeaking sounds on dips / rough roads
    My car has 48,xxx on it and has a stock non-sport suspension. Sometimes when I go over dips or rough roads with bumps I hear noises after it rebounds. Kinda sounds like perhaps a squeaking sound?
    Would it be the control arms? I'm trying to narrow it down so I can get it repaired under warranty.
    Thanks,
    Nick
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    Re: Squeaking sounds on dips / rough roads
    check to see if your upper control arm bushings on the problematic side have any play in them
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    I had a similar problem; my friend figured out one of the screws on my exhaust was loose and rubbing. It's a long shot, but it doesn't hurt to take a look at it.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    i get the same thing when i hit a bump, its a weird squeak. been trying to figure it out for a while now.
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    x2 i have squeaks but i have oem sport suspension.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    It is funny you say that, I was driving a few days ago on a bumpy street and I thought I heard the same thing on the PSNGR side of the car. I couldn't tell if it was birds chirping as I was driving by or my suspension. Coming up on 50k, so for my last trip to the dealership under warrenty I am going to have them take a look.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Check outer CV joint and CV boot. The boot may be cracked and leaking out the packed grease. It can cause the squeaking sound.
    USP CLUB MEMBER #34
