Results 1 to 14 of 14
    Established Member Two Rings Mr Kram's Avatar
    May 04 2005
    2011 911 Turbo S
    LA
    Brake Upgrade for 05 Allroad?
    What's out there? I talked to my tuner, but he is somewhat unfamiliar with Audi products. He could only find an upgraded Brembo package for the fronts. What about the rears? This is a 2.7T BTW.
    Mar 27 2005
    The Cold North
    Re: Brake Upgrade for 05 Allroad?
    i know a guy in denver ended up installing a STaSIS BBK in the front and the STaSIS rear rotors w/ S4 calipers in the rear on his 2003 Allroad 2.7T (w/ Stage 3+ motor). Look up gragraver on Audiworld.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    May 04 2005
    2011 911 Turbo S
    LA
    cool. thanks.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by Mr Kram View Post
    STaSIS for sure. LMK how we can help!
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    May 04 2005
    2011 911 Turbo S
    LA
    jeremy, does stasis have a direct bolt on product? if so, what are the costs?
    May 27 2004
    Portland, OR
    Yes;
    STaSIS TrackSport 13" Mono4 front brake kit for B5/B6/B7 A4/S4/A6/AR 2.7T; 2 Alcon Monobloc 4-piston calipers, 2 13" x 32mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets and hardware, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
    STaSIS MotorSport 13" Mono6 front brake kit for B5/B6/B7 S4/A6/AR 2.7T; 2 Alcon Monobloc 6-piston calipers, 2 13" x 32mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets and hardware, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
    STaSIS TrackSport 14" Mono4 front brake kit for B5/B6/B7 A4/S4/A6/AR 2.7T; 2 Alcon Monobloc 4-piston calipers, 2 14" x 32mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
    STaSIS MotorSport 14" Mono6 front brake kit for B5/B6/B7 S4/A6/AR 2.7T; 2 Alcon Monobloc 6-piston calipers, 2 14" x 32mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets and hardware, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
    STaSIS TrackSport 14.5" Mono4 front brake kit for B5/B6/B7 A4/S4/A6/AR 2.7T; 2 Alcon Monobloc 4-piston calipers, 2 14.5" x 32mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
    STaSIS MotorSport 14.5" Mono6 front brake kit for B5/B6/B7 S4/A6/AR 2.7T; 2 Alcon Monobloc 6-piston calipers, 2 14.5" x 32mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets and hardware, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
    (Through 7/4/08, we're running a promotion where with a front BBK, you get a free 2nd set of pads (street, street/track, race).
    STaSIS TrackSport 11.7" rear brake kit for C5/Allroad; 2 STaSIS 298mm x 20mm vented/gas slotted rotors, 2 STaSIS rotor mounting hats, 2 STaSIS carrier mounting brackets, Ferodo 2500 high performance brake pads, Goodridge braided stainless steel brake lines (rear only), Motul 5.1 high performance brake fluid
    Please PM or email me for your price shipped.
    Jeremy Williams
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    is the hp2 on the fronts worth the cost
    or just buy a good pad for the FRN-G60?
    thx
    May 27 2004
    Portland, OR
    Quote Originally Posted by white fish View Post
    thx
    Are you asking if the HP2 calipers are a good caliper?
    Jeremy Williams
    Feb 21 2004
    T.O.
    well I thought they were better then the FRN, arent they?
    but is it worth the cost of changing to them on an 05 allroad
    May 27 2004
    Portland, OR
    HP2 calipers are good, the rotors that come with them on B5 S4's and such just aren't great.
    Jeremy Williams
    Feb 21 2004
    T.O.
    they are the same rotors on the 05 allroad right?
    May 27 2004
    Portland, OR
    Yes;
    12.6"(321x30mm) front brake rotor for B5 S4/A6/Allroad 2.7T, AR 4.2L, B7 A4 2.0T
    Jeremy Williams
    Feb 21 2004
    T.O.
    ok so my question is
    are the HP2 better then the FRN with good pads?
    May 27 2004
    Portland, OR
    That's one that is hard to answer. We like HP2 calipers save for the OEM rotor/pad combo and the tendency to create uneven pad deposits = "warped" rotor sensation.
    Jeremy Williams
