Results 1 to 6 of 6
    Senior Member Three Rings FrancoTheTanko's Avatar
    Jul 12 2007
    San Jose, CA
    Boost leak test drip?
    I did the boost leak test from A4mods.com for shits and giggles yesterday. First of all, my boost gauge barily went past 5psi and after that I started to hear a dripping noise in the engine. It doesn't hold the pressure for a very long time either. Any ideas?
    Now: 2008 RS4 Phantom Black Ti
    Then: 2001.5 A4 1.8TQMS Black, GIAC GT28RS elim
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Boost leak test drip?
    you have a boost leak? and need to find it? just listen for it and where its coming from
    Jul 12 2007
    San Jose, CA
    I know, I forgot to say I couldnt hear anything. And I'm holding around 18-20psi in 5th anyways.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    The dripping noise is the oil bubbling. Its normal for us, just make sure you have the pcv system blocked off at the intake. What to listen for is a hissing noise. Also, boost leaks are way less noticable in higher gears since there is more load on the motor to help create boost.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I think the only way to make it hold the pressure is to set the engine so that all the intake valves are closed, other wise the air is just going thru the valves and out the exhaust or past the rings into the crank case.
    Jul 12 2007
    San Jose, CA
    Yea I figured some air would leak through the valves but I thought my boost gauge would more or less mimic the gauge on my compressor. I guess I didn't really need to do the test, I was just looking for something to do.
