Thread: strange part
    Sep 01 2007
    2000 S4
    Columbus, Ohio
    strange part
    So I popped the hood tonight and saw a rubber flap looking thing behind the hood latch connected by two rubber prongs and infront of the tbb that was dangling. The bottom half of it was torn to shreds by either the fan or the timing belt and left little rubber bits everywhere. I didn't have much light but does anyone know what that piece is and should I be worried at all? Thanks
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    Re: strange part
    It's a cover for your hoodlatch assembly, the same thing happened to mine. The belt you are referring to is the serpentine/accessory belt not timing ;) as far as replacing it, I have had mine off since this happened. Without it your hood latch is just exposed to the elements a bit more! see if you can't cut off the bottom and get a decent fit with at least partial protection!
    Sep 01 2007
    2000 S4
    Columbus, Ohio
    Re: strange part
    ok good to know thank you. And thanks for the correction haha.
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    Re: strange part
    at least you still have your hood release so lady backed into mine and broke off the part that sticks out of the grill, grrrrrrrrr
    2000 s4
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: strange part
    Same thing happened to mine, I removed the mangled rubber piece and so far things appear okay.
    Nice to have all that rubber flaking gone...
    Brilliant Black 2001 S4 - 6MT <3
