Results 1 to 11 of 11
    Sep 19 2007
    seattle
    Could you please take a look
    Hi,
    Could you please tell me if this is what's shown on your b7 S4 as well...
    1) Is the temperature a bit high on the left of this photo (the needle is in the middle between C & H)? Every car I have had, the needle tends to be more on the left...but this car always has it in the middle, which looks high to me.
    2) I hit the 'CHECK' button on the dash board and that 'yellow lightbulb thingy' above 'oil pressure' shows a 'red cross' on top... Does that mean oil pressure is abnormal?
    Thank you in advance for any help you could provide...
    p.s. Btw, my 'Check Engine' light is off now...weird...
    John
    Dec 05 2006
    So. Cal.
    Re: Could you please take a look
    The temp guage on the S4 and the RS4 should read right smack dab in the middle.
    All the lights that are currently lit (while the car is not running) in that pic should be lit to tell you that they are working. Once you start the motor everything should turn off. If something is still lit while the motor is running, then you have an issue.
    Sep 19 2007
    seattle
    Ed, thanks! So the needle is at where it should be then?
    My 2nd question meant to be 'how come there's a red cross on the yellow light-bulb thingy'? Did your S4 show a cross, too when you hit CHECK button?
    Thanks...
    Dec 05 2006
    So. Cal.
    When you hit the check button, it will light up every warning light on the dash. It does this so you can see when a warning light has gone out. That light bulb with the red x is one light. You will never see the lightbulb without the red X as it is a warning let you know when some sort of light ahs gone out. Look at the first few pages of your manual, it'll show you exactly what that light means. once you fnd out, post it up here as i don't know what it means either.
    Sep 19 2007
    seattle
    Got it! I just read the manual and that thingy is to tell there if there's a defective bulb... I got confused and thought that had to do with oil pressure...
    thank you!
    Senior Member Two Rings MikeS4's Avatar
    Feb 14 2008
    searching for something new
    Savannah
    yeah that lightbulb is not fun to see. because when you do get a lightbulb thats burnt out, such as a tail light in my case, it takes up the whole damn DIS untill you fix it. good motivation to get it fixed though.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    temp gauge should be right in middle as Ed has specified earlier...so what was your CEL from ?
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    I have had the lightbulb with an X when a bulb goes out too. It usually comes on when the car starts and will stay on until the bulb is replaced as Mike S4 points out. However, each time this has happened, if you push the check button while the car is running, it should display what light is bad. I don't know if this is common or not, but on my car, this works two ways depending on what bulb it is. For example, when I put in LED license plate bulbs, almost everytime I start the car and the lights go on in auto mode, I get the bulb with the X, the loud tone (same one you get when the gas is low) and it then says, plate light. This will go off shortly after starting the car. If a stop light bulb has gone out though, I get the X and then have to push the check button to see what bulb it is.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Sep 19 2007
    seattle
    Thank you all for the replies!
    Channad, you mean where the nickname came from? It's just something out of the blue...
    Dec 05 2006
    So. Cal.
    check engine light.
    Sep 19 2007
    seattle
    check engine light.
    I see...
