Results 1 to 15 of 15
    Veteran Member Four Rings A4_cabrio's Avatar
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    Need advice to clean my wheels from the gunk off the street
    I am so pissed right now.
    The f...ing a..holes in my city decided to "rejuvenate" the streets in my neighborhood.
    So they laid this sticky stuff along with sand or something like that.
    I drove as slow as I could but that stuff still clung to my wheels.
    I have the hyper silver RS4s from VMR. It's stuck mainly between spokes and at the corners of the larger openings. And inside the wheels.
    I tried powerwashing my wheels but a lot of the sand and the sticky stuff couldnt be removed. It's almost like tar or something - it wont go with soap
    Does anyone know of a good product to use? - I dont want to ruin the wheels nor scratch them
    Appreciate your help in advance.
    2005.5 2.0T Tip Dolphin Grey / Black Interior
    Factory options: all except for Bose sound
    Added: 35% Tint, OEM Bluetooth, MFSW with paddle shifters, RS4 pedals, Brushed Aluminium mirror caps, S-line bumper, RS4 grille, Euro plate filler, 19" RS4 reps (Velocity), S4 valence, Satellite receiver, Quad tips, VMR boost gauge, AUX port
    Next mods: honeycomb fog grilles, LED DRL, Dension
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: Need advice to clean my wheels from the gunk off the street
    you can try bug & tar remover. it is safe for all paint so can't see why it wouldn't work on wheels. I use groits tire/wheel cleaner with a little scrubing thing and it does pretty good to get the brake dust and whatnot off.
    The usual things!!
    Resistor Install
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i use dp wheel cleaner and wheel glaze. it usually does a nice job and helps keep brake dust off. not sure if it'll be strong enough for that nasty stuff you found, but good luck!
    Established Member Two Rings lak2881's Avatar
    Mar 12 2007
    A4 B7 Sline Ti pkg.
    simple green works really well.
    2010 A4, 6sp quattro, Sport package, Bluetooth, Homelink.
    2007 A4 S-Line Ti Pkg 2.0t 6sp fronttrack, H&R Sport Springs, H&R rear sway bar, Front filler plate, debadged, 35% window tint, REVO, 10mm front 12mm rear H&R spacers.
    2004 A4 1.8t 5sp fronttrack, H&R sport springs. Forge diverter valve.
    Senior Member Two Rings reggaemylitis's Avatar
    Apr 19 2008
    06 A4 Avant 2.0TQM
    South Lake Tahoe, CA
    try a clay bar. Might be hard to get between the spokes though. It seems that a clay bar will work on anything, even the herps.
    APR Stage II. AWE Exhaust. AWE FMIC. Forge DV. JHM Short Shifter. RS4 Rear Sway. 034 Turbo Inlet Hose.
    "We're going to sodomize our vast imaginations with this pornography!" -Ignignokt
    Veteran Member Three Rings freeflow's Avatar
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    ^^^ hahaha
    2007 A4 2.0T - Brilliant Black on Black - Premium - 5% tint - 7 spd multitronic - APR 93/Stock - RS4 Sway - FLY's LEDs - CC'd - LED License Plate - Interior xenonmatch - Hoen Fogs - Debadged - VAGed
    Wish list: Stassis Coils, Carbonio CAI, HFC, 19" R8s, Ecode CF Hood, CF Rear Wing, ECS Blackout RS4 grille, S4 blades,
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    +1 for clay, then give it a coat of wax/sealer
    -Kris
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    Quote Originally Posted by lak2881 View Post
    definately does 50/50 simple green and water
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by slimmj0k3r View Post
    yah. definitly don't use it full strength or you'll run the risk of stripping the clear coat. I like to use P21s, but I don't know if it's strong enough to get tar and sap off
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    thanks for all the advice. The sad part is that three months ago - I had polished and waxed them. Most likely I'll have to do it again. It's just so hot these days in Texas. Can only do it in the evening since I dont wake up early in the weekends.
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    BTW: I am thinking to get the Mother's ball to polish and wax them after I remove the sticky stuff.
    Jul 31 2005
    Arizona
    mothers mag and aluminum polish works too
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    talk to your town/city hall and have them reimburse you for the problem to get it cleaned up professionally. If they did not warn you then they should cover it. people don't even think about trying this and for the minimal amount of complaints they may be nice to you
    Jan 01 2008
    Long Island NY
    power washer ftw.
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    Quote Originally Posted by Auditude2.0T View Post
    power washer ftw.
    Tried that first. It wont work. That shit is sticky.
