    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    Safest way to clean engine bay?
    I would normally just take a power washer to it, but with the amount of things under the hood on the 2.7 and with my high miles im reconsidering it. I have my engine covers off as well to make matters worse. Any suggestions, or should i just blast away?
    S4
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Safest way to clean engine bay?
    Well, I was at a car show and saw a mustang guy showing his buddies how nice his engine bay looked while he sprayed tire foam all over it....ooohhhhhh nice and shiney... NoT ReccoMenDed!!!! Not only the fact about owning a mustang.
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    uhh i use simple green and a rag to get in the small area.
    start your car.. let it run till its a tad warm.. spray simple green everywhere.... let sit for 10 min or so.. then START THE CAR
    get your hose out.. medium spray.. and spray it down... making sure to keep away from electrical parts that could get damaged.. listen to the car as your doing it to make sure its not stalling/sputtering when ur spraying it.
    rinse..and repeat if necessary.
    and tire shine isnt bad for your car.. i used to do it when i went to shows and stuff.. honestly it works great to get that show shine but i wouldnt do it all the time..i it makes a mess somteims.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Feb 28 2007
    chicagoland
    a couple pics of how my engine bay in my civic was kept with using the above methods.
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I used some Gunk foaming engine cleaner I bought at the auto parts store. It worked well and was quick.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
