Results 1 to 23 of 23
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Cylinder Misfires
    Went to Advanced Auto this morning for the check engine light and the codes came up as cylinder misfires for all 4 cylinders. Person there said it might be the spark plugs or the wires. Wondering if anyone had this before and had some advice on it. Thanks
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: Cylinder Misfires
    I get misfire codes all the time. I cant keep my check engine light off if I had to unless I run low boost and timing. And I have changed plugs and coil packs and get them still so doubt that will do anything for you. It isn't a big deal though.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    May 03 2008
    A4 B6 USP
    Orlando, FL
    K, I am taking it to someone nearby who has a Vag. See what we will find. That check engine light is annoying. I have to get it fixed. That's all I stare at when driving besides the road.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Have you noticed extra fuel consumption?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 08 2008
    Calgary AB Canada
    could be a vacuum leak...
    ive got one right now and i get misfires every so often
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by dirtybrd View Post
    No I haven't noticed. I know my brake light switch is bad b/c my brake lights stay on when my foot is not on the pedal. Could this cause a check engine light to come on? O and my ESP light comes on too.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Yes, it will and it causes misfires too. Fix the brake switch.
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by 400HPA4 View Post
    Really? If that is the case then I will fix it ASAP. I hope the switch is causing the check engine light too!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Senior Member Two Rings MAJI's Avatar
    Dec 06 2007
    B6 1.8T Quattro
    Santa Ana
    the brake lights most likely mean you are low on brake fluid and the misfires are coming from the coilpacks.. they need to be replace.. i just got mine back from the dealership...
    I LOVE CARS
    Present Cars: Audi B7, 2007 Mustang GT - Buliding in progress. Supercharger kit, 1993 Off-road Range Rover, 2004 Toyota Sequoia
    Past Cars:
    Audi B6, Lexus SC400. 1967 Mustang, 1997 Honda Prelude, 2002 Dodge Ram
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by MAJI View Post
    Thanks for the info. I will check it soon.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    I purchased my B6 a few weeks ago in Orlando and the VAG showed prev misfires on all cylinders. But there were a bunch of other codes too, and it appears that a lot of the codes were due to a low battery, which was replaced a couple days before I got the car, or to the dealer pressure-washing the engine. When you get access to a VAG-COM (and after you fix the brake switch etc), clear the codes and see what comes back. I have a VAG-COM, so if you're near WPB anytime, LMK.
    Quote Originally Posted by A4 TSCHUSS View Post
    Why is getting misfire codes all the time not a big deal? I would be quite concerned.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Apr 24 2005
    E55 AMG, CTS-V
    I have been getting them for 2.5 years ever since I had my GTRS if I run more than like 18psi of boost and any timing. And have been through coilpacks, plugs and a maf but they still come every so often. It isnt something I notice, it is just the check engine light comes on which is annoying.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    The brake light switch is freaking out the ABS/EPS and closing the throttle plate.
    I'm back bitches!
    Established Member Two Rings A4DJ's Avatar
    Apr 22 2008
    '05 S4
    Colorado Springs
    I just had this happen to me.. thought it was coil packs at first.. changed them all out and finally ended up bringing it to Audi and threw 8 codes. Turns out a Check Valve exploded and had a MAJOR vacuum leak.
    May 21 2007
    Florida
    Quote Originally Posted by Firefighter637 View Post
    reason you dont listen to people who work at autoparts stores. we have coilpacks, not plug wires. and yes...coilpacks seem to die frequently on these cars for some reason. theyre only about $30 at the dealer. depending on your miles...you may need spark plugs too. OEM were made to last 50-60k. i just did mine at 69k and they were the originals. car drives much smoother now.
    2018 Navarro Blue Q5
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by B6 Dude View Post
    Thanks for the info and the offer on the VAG. I have a guy that is nearby who has a VAG. I will be going there on Tues. Thanks!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by doublezero30 View Post
    Well it was close to my house and wanted to see what codes it said b/c I will be busy for the next couple of days. That's why I created this thread to get feedback before I buy or do anything. The car I just bought about 2 months ago and only has 31K on it. It kinda irritates me that I am having problems already at only 31K. Thanks for the feedback.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Also been reading that when the car is upgraded (ie-flashed) you should change out the spark plugs and check the coilpacks. Apparently the higher temps that the car produces from the higher boost levels causes the CP and spark plugs to go bad quicker.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    well i dont know how much of this brake switch causing misfires i believe, but you need to fix that, it will definitly disable esp and abs function and is very easy to replace, misfires on all 4 cylinders, id be suspect of fuel delivery first, check fuel pressure, do a amp draw on the fuel pump make sure its not drawing excessive amperage, next i would check for vacuum leaks, spray some carb spray around the intake manfold with the car running if it starts to stumble or you hear the idle speed raise you have a leak somewhere, if not on any of those fronts, your maf may need to be replaced.
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by brewmastr View Post
    The ESP light came on a few days ago while driving. Read that it is prob the brake light switch b/c my brake lights stay on while driving w/o my foot on the pedal and....the CEL came on yesterday. So I figured it was the brake light switch causing the CEL, but from reading other threads and from what you guys are saying it is something else. I am getting it VAG on Tues. Thank God!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Fixed the brake light switch and the ESP doesn't come on anymore. Changed out the spark plugs and the cleared the check engine light and hasn't come back on yet!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    good to hear! i had my injectors changed when i went stage 2 but nothing else.
    you coming over to the fg cookout next sunday??
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by pyro View Post
    I will be in Miami for the weekend. Sorry. I wanted to go though. Thanks for the invite.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
