Originally Posted by
The_Jerbel
Either way, they'll both help. If your stock center diff mount is dead, then upgrade to the apikol. If your stock mount is fine, then you'll benefit much more from the DTS.
Jordan, you are a bit skewed in your replies. The
DTS serves a different purpose than the
Apikol rear diff mount and subframe bushings. The diff mount itself almost completely eliminates the driveline slack or "clunk" you feel when you press the accelerator on and off, because:
a) It uses a firmer "poly" insert which has a carefully selected durometer made to eliminate excess driviline movement without creating unwanted vibrations. You can also opt for the firmer red bushings if you have a purpose built car.
b) The bushing sits flush in comparison to stock and eliminates the gap between where the stock rubber bushing stops and where it meets the chassis.
The DTS helps to eliminate the torsional transmission movement. I would say throw in the Apikol diff mount and see how awesome of a job it does, and then you can accompany it with the subframe bushings, DTS, 034 mounts etc. Mounts are a pain to install if you are not dropping the motor and the snub mounts really do very little in terms of eliminating slop unless your stocker is trashed. It is however a great idea if you are doing the timing belt to replace the snub while you're in there.
