Results 1 to 19 of 19
    Sep 20 2004
    2001 a4 quattro
    Sactown
    aftermarket Door Trim? lltek trim?
    Does anyone know where i can get lower door trim like this?
    the lltek trim seems really cheap, all 8 pieces for 44$. i dont see how that can be. does anyone have it and have a picture? thanks alot guys
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Re: aftermarket Door Trim? lltek trim?
    nobody?
    Dec 14 2006
    Halifax, NS, Canada
    I think that is the price to have them painted.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Dec 05 2007
    You had a post on this the other day. You should still purchase them from the original seller if I am reading this correct. The other post said you that it did not come with hardware and Bassed said you don't need it.
    Quote Originally Posted by bassed View Post
    As in not OEM. It's trim guard. OEM will fit with those, if that's what you want. Trim once pulled will never seat right again, it's the luck of the draw if you get to pull it and have it go back on the same. You don't need any hardware for mounting them. 2 sheet metal screws with good washers with the neoprene skirt (prevents cracking the skirts) up front and in the rear along with 3m tape underneath the whole length of the skirt and you're done.
    I have the reps, which are what you're looking at buying. True A!avantgarde skirts are impossible to get.
    Sep 20 2004
    2001 a4 quattro
    Sactown
    im not talking about the mounting hardware for the skirts, imt alking about the lower door trim, lltek has it as:
    LLA48D-16 A4 B5 8 pc Vinyl Molding Lower Door Trim FF
    ATP/GG $55
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    i have them. they do cost 44$ but that price is unpainted. they are really nice but i do not have a picture of them on my car. if you get them, be careful putting them on, make sure they are centered, mine are a little off. and even though no one can tell, it bugs the hell out of me.
    why didn't i buy a rs4 gill when they were $60
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Id like to get a picture as well. I think I am just going with the S4 door molding though.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    I'm pretty sure if you look at their site, its something like $44 for the pieces, and then to have them painted to match is like another $150-200. Something like that...
    Sep 20 2004
    2001 a4 quattro
    Sactown
    i was just wondering if these are the lltek lower door trim that you have?
    also what is the difference between the stock trim and the lltek trim? im looking for door trim that will be able to be painted without chipping. the stock trim is soft rubber, is the lltek trim stiff hard rubber or the same soft stuff like oem? also does the lltek trim protrude from the bottom of the door like the oem does? its hard to explain but i mean does the trim rest on the side skirts when the door is closed like overlapping the sideskirts or does it sit only on the door? thanks sooooo much, this will be of great help to me.
    Veteran Member One Ring
    Feb 13 2004
    A4 M3 996 Aero
    Columbus, OH
    Could someone please post the direct link to the LLtek lower moldings. If I looked quickly and couldn't find them. Also they require removing the pins for the stock lowers as their lowers are stuck with adhesive tape and not on the pins like the OEM lowers correct?
    Thanks
    Andy
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Sep 20 2004
    2001 a4 quattro
    Sactown
    FUCK FUCK FUCK FUCK FUCK FUCK LLTEK dont ever buy anything ever from them they charged me 55$ plus 42$ shipping for some goddamn 3m vinyl tape shit, they can all rott in hell!!
    Feb 27 2005
    North Wales, PA
    explain.....
    Sep 20 2004
    2001 a4 quattro
    Sactown
    their lower door trim is just some some goddamn 3m vinyl adhesive shit
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    their lower trim is nice, used to have it on my b5, its pre cut, fits perfectly, and is a hard vinyl, so it wont chip or flake the paint easily as painting cut stock lower painted trim
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by a4rings View Post
    does it work though? I though about using some wood and cutting up some in my friends wood shop and sealing and painting it.
    May 28 2007
    Northern Virginia
    considering getting this for myself...
    Sep 20 2004
    2001 a4 quattro
    Sactown
    if i was u guys i would just look on the 3m website and find this rubber shit and just cut the pieces yoursleves. thers no way this stuff costs 55 bucks.
    May 28 2007
    Northern Virginia
    Not to seem lazy (which it probably appears to be) but I honestly don't know what this stuff would actually look like up close. If you get the opportunity and have some extra time could you look and possibly post up a link? Thanks!!! I'm gonna start searching now to see what I can find.
