Results 1 to 9 of 9
Thread: LED whore...
Hybrid View
    Veteran Member Four Rings tiptronic's Avatar
    Dec 24 2007
    2016 Hyundai Tucson Limited 1.6t
    San Gabriel Valley Los Angeles
    LED whore...
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Re: LED whore...
    niiiiiice!!!
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Dec 24 2007
    Re: LED whore...
    Quote Originally Posted by channad View Post
    niiiiiice!!!
    hey channad! long time no see! Hopefully i get spotted with these by other Audi-ers...
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Re: LED whore...
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Feb 13 2008
    Re: LED whore...
    nice. i like the 2nd pic.
    07 RS4 - Milltek Sport, KW V3s, Hotchkis Sways, Rotiforms and a few other little things
    13 A6 2.0T - Intentionally boring AF so she stays stock
    Missed: cbock's Stage III+ C5 A6
    Dec 06 2007
    Re: LED whore...
    i love the DIY u wrote up where are the headlight LED's???
    -Kirk
    BetaAlphaTau Member #58
    Dec 24 2007
    Re: LED whore...
    Quote Originally Posted by AudiA4Turbo22 View Post
    The headlights (FK projections) are being re-modded with these brighter LED. Im running into some issue with proper mounting material and clearance - to make sure all 12 LEDS (on each headlamps) are in proper formation and distance wout looking too aftermarket(?) and wout affecting normal headlight operation (adjustments and wirings)
    The style will be similar to the new TT-S leds- the S5 LEDs are far more complicated- it's a specially made/collimated lens and housing that gives that bright glaring effect, even under daylight. The LEDs i have currently are far better than my previous LED stripz. These new LEDs can be seen as a conformed point of lights under true sunlight/daylight. And very bright in shades and nighttime.
    Hopefully i can come up with a solution by end of this week, cause i miss my HIDs damnit!
    The "new" current Fog Grill LEDs were installed (measuring, drilling, wiring, gluing, connecting and testing) both sides- in 2hours! thats how easy it was! (providing all materials are ready on hand).
    e
    Dec 06 2007
    Re: LED whore...
    ^^can u make a set for my B6?? and are they strong in terms of light output or just show??? i would prefer 1 watt LED's!
    -Kirk
    Dec 24 2007
    Re: LED whore...
    A 1 watt, or higher watt LEDs will require extensive wiring, proper resistors and proper mounts with heat sink and even a proper cooling system if mounted in an enclosed area. 1 watt leds produces heat.
    These LEDs are 4chip design- 4 Light emmiting diodes crammed in one small space (about 5mm) and a dome lens-produces very bright output. They are borderline for show, and ''driving'' lights as in DRLs cause people do take note/twist head when they see the car, even under daytime. The natural recess of the Fog Grills also acts as hoods/shades so yes- they can be seen during daytime driving.
    e
