Results 1 to 11 of 11
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    testing icm's???
    this article http://forums.audiworld.com/a4/msgs/1594531.phtml is for 4 cyl. they say the neg - should NOT be moved from terminal 3. can anyone tell me what post it should be on for testing our icm's or a write up specific for our cars?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: testing icm's???
    Not sure, but if your testing your icm because of misfires all on the same bank just swith them up, log and see if the misifres switch banks.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Dec 06 2007
    Calgary, AB, Canada
    Play with it and see which terminal gives continuity with the other terminals...
    May 06 2007
    Quote Originally Posted by The_Jerbel View Post
    see i thought i found it but not all terminals have a reading. dead?
    May 06 2007
    when i swap icm's around i find this... one way it has a cyl misfire in cyl 3 and 5 with 3 being the worst. 1 and 6 have 0 misfires and cyl 2 and 4 have 1 or 0. now when i swap them cyl 3 still has misfires but not as bad. now cyl 4 and 5 have them and there are more in cyl 4 than 5. cyl 4 went from having 0 or 1 misfire to having like 9 or 10. kinda confusing but hopefully someone understands it lol
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    I had that same problem and replaced my o2's on a whim cause my car hit 90k on originals and made sure the plugs were gaped at .28, cause 3 was at .30 for some reason it stoped the misfires.
    2000 s4
    May 06 2007
    Quote Originally Posted by readimag View Post
    new o2's and tried every gap form .024 to .028. no difference at all.
    Dec 06 2007
    Calgary, AB, Canada
    Have you replaced the ICM's already?
    May 06 2007
    no
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by volks88 View Post
    Sounds like it...
    Established Member Two Rings Cartells's Avatar
    Jun 13 2012
    Rhode Island
    how do you test an ICM with a multimeter? and yes this sounds like your ICMs for sure. just had the same issue
