Results 1 to 34 of 34
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Apikol Snub Install - Pics --->
    Just installed my Apikol snub mount. Very easy. Hardest part was getting the GD belly pan back on. Here are some pics/comments:
    First, this is my new Euro plate - I know - most people will think it means "I urinate on the law." It stands for "intellectual property law" - my profession. In retrospect, should've picked something less Bart Simpson... And yes, that's my Dolphin Gray tow cover on a Lake Silver car - don't know why the previous owner did that...
    These two pics show the old mount - you can see the dark area where it was hitting the bottom of the cup - I guess that's the "clunk" we feel sometimes:
    Here are some comparison shots between the mounts. The Apikol is obviously bigger. I was worried about fitting it in the cup, but it fits perfectly. I had to drop the cup all the way down to work the mount back in, but as shown below, that was the sweet spot for tightening the cup back down.
    This was my prep for getting the Apikol on. I had read so much about how hard it is to jam a new one on - the Hot Dog Heaven cup has hot soapy water. I didn't need it - just peeled the old one off and banged the new one on.
    Here's the fit of the Apikol:
    This is the right side of the cup. As you can see, the cup is adjusted as far down as it can go - luckily that was exactly where it needed to be - no vibration.
    This is the left side of the cup - notice that mine only had 3 bolts to adjust - two on the right, and one on the left.
    IMPRESSIONS:
    The only reason I did this mod was because I found out my OEM mount was starting to crumble. I didn't think I had any vibration issues. I do feel the clunk every now and then, but I attributed that to sloppy shifting.
    After test driving around the block - wow - I can really tell a difference. It wasn't until feeling how smooth the car is now that I realize that it was a little rough before.
    Very pleased with it. I hope it holds up!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    Re: Apikol Snub Install - Pics --->
    I think you're supposed to leave the screws loose and let the engine idle for a minute, then tighten them. Am I right?
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Dec 06 2007
    ^^i Think Thats For Motor Mounts, But I'm Not Sure!
    -Kirk
    BetaAlphaTau Member #58
    May 03 2008
    Orlando
    Quote Originally Posted by SeKKeY View Post
    Yeah - that's to adjust it. I left the cup screws loose, backed off the ramps, let it idle for a minute, pulled back up and then tightened - that's not the proper way - pulling back up on the ramps can bias the settling from the idle. I didn't really have a choice anyway - the cup had to be all the way down or else it would have hit the bottom of the Apikol. Luckily, it worked out!
    Kevin W.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    ya, you should def. leave the screws loose, rev engine a few times and then tighten. if he is not feeling any excessive vibration then he got lucky. i always put my leg up against the front bumper and if its shaking, then i know i need to adjust.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Buncha motorcycles
    Memphis, TN
    i was very impressed with APIKOLs service and their warranty, unlike APRs junk lately
    APR Stage 2/AWE Intake
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    I went the APR route, but same install. I agree the BP install was a PITA. Anyways mine was centered the first time correctly and have had no vibrations or issues for 2 weeks going. I should prolly get under there just to make sure but so far no issues!
    Nice pictures and write up!
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    I installed my APR snub last week and prob need to adjust it b/c it vibrates at idle. I read that you keep the car running when adjusting and tightening the bolts once it settles.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 03 2008
    Orlando
    Ok - regardless of my lucky success, here is the right way, as told by old guy:
    Find a slanted area where you can set your ramps at the bottom of the slant so that when your front end is on the ramps the car is sitting level instead of being up in the air. Install the snub mount as instructed and leave the mounting "cup" that is bolted to the back of the front end loose. Start the car and make sure it is fully up to operating temperature. With the car at idle CAREFULLY reach up and move the mounting "cup" around until you have it completely centered. I say carefully because you will have your fingers about 6" from the spinning crank pulley. It really isn't as dangerous as it may sound as long as you pay attention to what you are doing. It is very easy to tell because when it is completely centered you will feel minimal or no vibration. I have a trimmed Neuspeed and I can center mine to where there is no contact between the "cup" and snub bumper at idle. Once you are comfortable with your positioning, tighten the lower bolts on the "cup". Turn off the motor and tighten the upper bolts. With this procedure you should be able to get a vibration free idle.
    Kevin W.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by Firefighter637 View Post
    Nope like Sekkey said the car has to be off.
    http://www.goapr.com/Audi/support/b6_snub_mount.pdf
    Nice write up!
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    May 03 2008
    Orlando
    Quote Originally Posted by FourRings80 View Post
    but not if you follow old guy's post - just be careful.
    BTW - aaronz - I took the pics with an Olympus SP-510 UZ. Used macro with flash for the closeups. Feel free to use the pics if you want. I have high-res versions if needed.
    Kevin W.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I got the same mount installed recently with 034 engine mounts. I alo got a bracket from 034 for the snub, but couldnt fit it, so used the stock one. I think im gonna redo that someday, somehow i should fit that. The snub barely goes into that bracket (which is good), it sits really tight, but the snub itself i guess is too big for that bracket. maybe i should cut a little piece off. Any suggestions???
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    IP Lit? Or IP Transactional? LOL I work in the Industry as well. So was it easy? I'm thinking of doing this as well.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    May 03 2008
    Orlando
    Quote Originally Posted by 04QuattroTurbo View Post
    Right now I'm a clerk at the firm - doing lit and trans - small IP-only firm. Take the Bar in July. When I start back, I'll focus on litigation, but when that's slow, grab trademark office actions. Transactional only on trademarks and copyrights. Was an English major, so I can't take (nor do I want to take) the Patent Bar!
    The snub install was very easy - no special knowledge or tools required. I didn't even need the hex socket - probably could have done it with a sturdy allen wrench. I wouldn't have attempted it if I had a B5 - at least not when I have important bar prep lectures to get to in the morning...
    Kevin W.
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by kwimberly View Post
    Good luck on the bar. Are you from a tier 1 school? Are planning on joining one of the "evil" empires?
    USP Member 110
    Jun 15 2008
    Fairfield, CA
    Just ordered my APR snub. Thanks for the writ of instructions! LOL
    USP Member 110
    May 03 2008
    Orlando
    P.S. - the Apikol seems to be less expensive than the others, and although it's relatively new, I haven't heard of one failing...
    http://www.avalonmotorsports.com/ind...roducts_id=312
    Kevin W.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Is this the same for 3.0 engines as well or is it slightly tougher?
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    I didnt notice a HUGE difference, but not alot of vibration at idle and a bit smoother shifting.
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by IronAudi View Post
    According to APR's site, the 3.0 has the same instructions.
    USP Member 110
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    hey guys i know this is a real noob ques but what is a snub mount and what does it do ... from what i've been reading it has to do with the engine and vibration of it or something to do with shifting ? thanx guys
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Active Member Two Rings AudiDWK's Avatar
    Mar 20 2008
    2005 B6 A4 1.8T
    Cerritos, CA
    Does this help with automatic trans? (CVT)
    Jun 15 2008
    Fairfield, CA
    I read from other members, here, that the snub mount is really an upgrade for the Manual transmission owners, you may get more vibration on the automatics.
    USP Member 110
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    I ordered one for my sisters CVT since her snub mount is the original one since 2002 and its busted. I think it should help her a lot, specially when taking off like on a red light (when it turns green of course) lol
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Sep 23 2006
    Houston TX
    much bigger PITA, front bumper has to come off. you can search for Eddieman's write up. Still not too bad, but probably a couple of hours for your first time.
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    Is that even possible? Just thinking it from a pure physics point of view. If the snub mount is the same on an automatic and manual, than why wouldn't this be an upgrade for both? They are engine mounts, not tranny mounts. If it reduces vibration for the manuals, than why not the automatics? I'm trying to conceive how it could possibly make it worst.
    I could be totally wrong, please feel free to correct me.
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    I have an automatic TIP with the apikol snub and it helps out alot. I used to get a bang when i floored it and it downshifted hard. now its nice, tight and less dramatic of a shift. no vibration at all. not sure what everyone is talking about there.....
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    I just installed my Stern snub. I guess you could say it was a bit overdue.
    CEO and General Manager of the AZ Pedal Responce Team
    Jul 11 2007
    Lakewood Cali
    i have a question when i did my timing belt i noticed when i put everything back together there was a slight bit more vibration nothing extreme but just a little bit....
    would this be because i just bolted up the stock snubmount and never did it according to specs?
    im thinking yes.
    lmk
    thanks!
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    nice, just in time, i should be getting my apikol snub in mail today
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Quote Originally Posted by A4Triple Blk View Post
    The snub mount reduces the rotational movement of the driveline that you get when you apply torque. The reason it helps the shifter is because the shifter carriage is bolted to the car body and the shifter linkage is obviously connected to the transmission as well as the shifter carriage. When the driveline moves in relation to the car body the shifter carriage has to slide on the carriage side rails to keep from breaking. The more you limit the rotational movement of the driveline the less movement you will get in the shifter.
    Thanks to "old guy" for that one in an old post.
    -Matt
    FCDT Member #1
    Active Member One Ring nvk289's Avatar
    Apr 11 2010
    Just installed my Apikol snub mount. Piece of cake install, and noticeably improved shifting. The car doesn't jerk as much when I quickly let out the clutch. Thanks for the write up.
    May 21 2007
    Florida
    just got my apikol snub in the mail, my stock one has twice the cracking yours did kwimberly! cant wait to get it installed this weekend. thanks for the writeup!
    just for clarification purposes, the three alen head bolds you tighten down, but the three socket bolts you leave a bit loose while you let the car run?
    2018 Navarro Blue Q5
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Yes
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
