Results 1 to 7 of 7
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Just bought a S4, list of codes lol
    So i bought myself a S4 to replace the A4 and just got it last night. my VAG is broken so i borrowed my buddies ebay one. it came up with these codes. Nice laundry list, sounds like it shorted out at one point, unless it can really have all these issues. lol
    Friday, 27 June 2008, 13:18:03
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 8D0 907 551 M
    Component and/or Version: 2.7l V6/5VT G 0002
    Software Coding: 06711
    Work Shop Code: WSC 06435
    10 Faults Found:
    17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
    P1455 - 35-10 - - - Intermittent
    17867 - Shareware Version. To Decode all DTCs
    P1459 - 35-10 - Please Register/Activate - Intermittent
    17869 - Shareware Version. To Decode all DTCs
    P1461 - 35-10 - Please Register/Activate - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17952 - Throttle Actuation Potentiometer - Signal too High
    P1544 - 35-10 - Please Register/Activate - Intermittent
    16622 - Shareware Version. To Decode all DTCs
    P0238 - 35-10 - Please Register/Activate - Intermittent
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
    P1172 - 35-10 - - - Intermittent
    16497 - Shareware Version. To Decode all DTCs
    P0113 - 35-10 - Please Register/Activate - Intermittent
    17704 - Shareware Version. To Decode all DTCs
    P1296 - 35-00 - Please Register/Activate
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
    P0106 - 35-10 - - - Intermittent
    --Black 2001.5 -S4- 10secS4 Tuned
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: Just bought a S4, list of codes lol
    Umm yeah... looks like you you either need to register that copy or get a different one, becuase that doesn't help much. lol
    But looks like you need to try a throttle adaptation and that might help with the angle sensor problem. I got a code like that when the wire harness on my throttle body wiggled loose while I was driving.
    Oh and you didn't scan for codes before you bought it??!! Man you are ballsy! I hope that doesn't come back to bite you, but judging by that nice long list you got there it doesn't look good. I just hope they are all just old codes that are still stored and need to be cleared. Good luck.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Well I bought the car from another state and he's a pretty cool guy. I was just s little surprised by the list. My giac ecu is going in so ill see what codes pop up after
    Jan 29 2007
    08 S4 00 S4
    MD
    Looks like an EGT sensor is in your near future and the ECU has been unplugged recently. Also may want to try throttle adaptation. The last code, check your MAP sensor on top of the TBB, see if it's plugged in tight.
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    Those have to be old codes stored on the ECU, I don't know how else to explain all that! That ECU was put in the car just a couple of weeks ago to replace an APR-chipped ECU that I sold. I have no history of the car it came out of, but if it was a salvage car that would explain everything.
    Past - '01.5 S4, APR Stage III
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    delete all those codes , drive the car for a week or so see if they come back. thats what i would do.
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Yea, codes havent come back since i put the GIACXR ecu in. once i drive it daily ill have a better gauge on things, sofar so good though.
