Results 1 to 11 of 11
Thread: s4 suspension
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    s4 suspension
    Is the s4 suspension the same as the sport suspension that is found in all the other A4's?
    If not, what is the difference?
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: s4 suspension
    It's better.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Sep 27 2007
    Boston, MA
    Re: s4 suspension
    Quote Originally Posted by Firefighter637 View Post
    It's better.
    How so?
    Oct 11 2007
    Suburbia
    Re: s4 suspension
    its def better.
    Sep 27 2007
    Boston, MA
    Re: s4 suspension
    Does the s4 suspension fit on A4's?
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: s4 suspension
    Quote Originally Posted by mister_tu View Post
    Yes it will fit and is better. You can also get springs to lower it and will work well together. You can get RS4 setup also or A4's. A little stiffer but better handleing.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    Re: s4 suspension
    Buy mine for $200 shipped
    Sep 27 2007
    Boston, MA
    Re: s4 suspension
    Quote Originally Posted by 10mpgS4 View Post
    PM'd.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: s4 suspension
    If you put S4 suspension on the A4 it will sit higher and the ride will not be right because of the weight difference of the engines. That is why lowering springs for the S4 are not directly applicable (recommended) for use on the A4, only the coilover kits which give specific springrates are applicable to both, the ones designated simply A4 or S4 are specific to their respective cars and aren't right for the other.
    Sep 27 2007
    Boston, MA
    Re: s4 suspension
    Quote Originally Posted by Cargo8 View Post
    I mean how much higher are we talking about? Like regular A4 sport suspension height or much higher like 4x4 type of ride?
    Dec 06 2006
    Re: s4 suspension
    probably higher. the V8 weighs a lot more than the 2.0T ... so that much difference.
