Results 1 to 9 of 9
    Veteran Member Three Rings RoadRage's Avatar
    Feb 09 2008
    '16 Allroad, '81 Vespa PX80
    Chicago
    Question Squeaking and a creaking
    So my car turned over 100,000 not too long ago, and now the sh!t's hitting the fan. When I get in the car, it squeaks. When I drive straight, it squeaks. When I turn, either direction, it squeaks. When I get out of the car, guess what, it squeaks.
    After searching and reading around here, it seems it could be any number of things. My first thought is control arms, then tie rods and cv joints? Possibly suspension?
    Where should I look first? TIA
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Re: Squeaking and a creaking
    control arm bushing is my bet.
    get under neither the car and have someone turn the wheel back and forth. While its moving put your hand on the control arms to see if one has a vibration in it more than the other.
    2004 Subaru Impreza WRX
    Aspen White
    Awaiting Confirmation Two Rings
    Jun 17 2008
    a4 1.8tqm
    Columbus, Ohio
    ^what he said
    Registered Member Two Rings kingdon's Avatar
    Jul 07 2007
    new york
    I had the same problem after I lowered my car, I Jack up the car and spray WD-40 on all the joints then turn the steering right and left. After I drove the car around the block a few times the noise went away.Try this first before you start changing front end parts.
    Feb 11 2008
    Falls Church, Virginia
    Check to see if the CV boots are ripped? The grease all sprayed out of mine and now I've got a never ceasing squeak when the car moves... I should fix that soon. XD
    Registered Member Two Rings Fuzz_Duster's Avatar
    Apr 15 2008
    Scottsdale/Prescott
    control arm bushings/whole arms are going. Just had mine replaced, and guess what, no more squeeking!! And it handles a tad bit better too, not so sloppy feeling in the front.
    2004 subaru wrx
    Greddy/HKS stage 2.
    Veteran Member Three Rings B5 Quattro's Avatar
    Feb 10 2008
    2000Audi A4, '88 VW Jetta 2.0l16v, 2011 Golf....
    Hamilton.Ont, Canada
    The back of my car is doing the same thing I need to find out if it is uper or lower C. arms. Ahh the fun !
    Feb 09 2008
    Chicago
    It's probably the control arms. I spoke with my guy the other day and we're just gonna do a quick temporary fix, ie; pierce them and inject them with grease and re-seal them.
    Aug 13 2007
    Quote Originally Posted by RoadRage View Post
    did it work?
    Aspen White
