So I'm learning that changing your wheels/tires and adding lowering springs isn't such a straight forward process. I've got rubbing in the front and my damn TPMS light is going off all the time. I've figured out the rubbing issue (remove the screw) but now have to tackle the TPMS issue. I've seen on some posts that new TPMS sensors are needed when you get new wheels. Is it possible to sure the OEM sensors off the OEM wheels, are they removable? If not where can I get the sensors at a reasonable price? Is there a way to disable the warning light on the B7 interface? Thanks.
